#344198 - 13/04/2011 08:23
Wireless PC keyboard that doesn't suck?
I'm looking for a wireless mouse and keyboard that doesn't suck. That is: - It must have the Ins/Home/PgUp/Del/End/PgDn cluster in the right place, and right order.
- It must have proper function keys. That is: not remapped to do odd things, and not half-size or half-height.
- It must have a Windows key.
I would prefer one with media keys, but not that fussed. I'm not bothered about Bluetooth vs. whatever RF, as long as it works with Windows 7.
#344199 - 13/04/2011 09:57
Re: Wireless PC keyboard that doesn't suck?
[Re: Roger]
You might want a Caps Lock and Num Lock LED as well. I know my wireless keyloard does not have one and that indeed sucks
#344200 - 13/04/2011 11:43
[Re: Roger]
Wow. That's oddly hard to find. I only found one — Kensington PilotBoard — and then realized you probably wanted a UK layout, and they don't seem to sell a UK version of that. Check to see if HP sells one. They sell a US keyboard that matches your specs, but their site seems hosed right now and I can't get it to load to search for either one.
#344201 - 13/04/2011 12:24
Wow. That's oddly hard to find. Yeah. Most modern keyboards tend to mess up the function keys (which I need because I use Visual Studio, and a lot of the keystrokes are function-key based), and the ins/del cluster, which just freaks me out when Del and PgUp/Dn are not in the right place.
#344202 - 13/04/2011 12:24
[Re: Redrum]
You might want a Caps Lock and Num Lock LED as well. I know my wireless keyloard does not have one and that indeed sucks Oddly, I don't think I'm bothered about that, but I might be once they're missing
#344203 - 13/04/2011 14:39
[Re: Roger]
I'm still very happy with my Logitech DiNovo keyboard + mouse combo (not the Edge variant, the classical DiNovo), but I don't know if they still sell it.
#344204 - 13/04/2011 14:54
[Re: Roger]
Just to clarify what that means, is this the right order? I understand what you mean about the function keys. It used to be that on laptops you would see the alternate functions on the F-keys, and you had to hold down something like an Fn key to use them. I see a lot of laptops these days that do the opposite, where you have to hold down the Fn key to get the F-keys, and I hate that. I have the Logitech K800, which I've really been liking. Unfortunately it doesn't seem to meet your requirements. The F keys are slightly more than half-height, but I think they're contoured in a way that makes up for that. They have a good feel IMO. The only negative I have for this keyboard is that the battery runs out pretty quick because of the backlight. I love the backlight, but while I probably replaced the couple of AA's in my old wireless keyboard every 12-18 months, I probably have to recharge my K800 every other week. It's not a big deal, though, I just hook up a micro USB cable overnight and it's done. Or I can keep working on it while it's charging. You didn't specify any requirements for the mouse, did you? Anything you're looking for there? I like my Logitech Performance MX quite a lot.
#344205 - 13/04/2011 16:06
I'd imagine he'd prefer a UK keyboard layout.
#344206 - 13/04/2011 17:57
Yes, I see. I wasn't familiar with the UK layout. I was only linking to that image to verify what he was talking about in the section I quoted above. He said he wanted that cluster in the "right" place, but how do I know what he thinks is the right place?
#344207 - 13/04/2011 18:02
Meh... the paint on the key caps doesn't matter, you can set your layout to whatever you like.  (says the guy touch-typing dvorak on a qwerty keyboard)
#344208 - 13/04/2011 18:26
[Re: canuckInOR]
I always wanted to play with Dvorak. I even set up my favorite free typing tutor, Stamina, to use it, but never got around to it.
#344209 - 13/04/2011 18:28
[Re: canuckInOR]
Anyone know why the US and UK layouts are so different? Wikipedia somewhat explains it with the need to type £ and € commonly instead of $, but what about historically before the euro? Why the extra keys, and different enter for example? Is it mostly just legacy from wanting one physical layout with different key caps for multiple languages in the European area?
#344210 - 13/04/2011 18:28
[Re: canuckInOR]
Meh... the paint on the key caps doesn't matter, you can set your layout to whatever you like.  Ah, but what does matter is the position and number of keys. And that UK layout has a different arrangement than my US keyboards and many other keyboards I've seen. As a quick example, there's an extra key between the left shift and Z keys. And if you use that keyboard without a UK layout at the software layer, you're going to have to start swapping keycaps around. But unfortunately (or fortunately?) it's impossible to make a single keyboard perform exactly the same way in every locale because of the software layers that remap the key codes. Not when using HID or key codes anyway. I suppose someone could make a keyboard with a micro-controller that spit out specific unicode strings. Then you'd be stuck with what was written on the keycaps.
#344211 - 13/04/2011 19:47
I understand what you mean about the function keys. It used to be that on laptops you would see the alternate functions on the F-keys, and you had to hold down something like an Fn key to use them. I see a lot of laptops these days that do the opposite, where you have to hold down the Fn key to get the F-keys, and I hate that. Yep I think that it's quite silly to have to press Fn-F2 ro rename or Fn-F5 to refresh but be able to adjust volume or screen brightness with just F1, F2 etc particularly when many laptops also have dedicated media keys for volume at least and brightness is not something that you change every few minutes. Dell's (at least a studio 17 has) have a setting in the BIOS to swap it back to original sane settings.
#344212 - 13/04/2011 19:51
[Re: Robotic]
I always wanted to play with Dvorak. I even set up my favorite free typing tutor, Stamina, to use it, but never got around to it. You can't "play" with dvorak, you commit whole hog. Typing is all about muscle memory, and playing will never get you to that point.
#344213 - 13/04/2011 19:53
[Re: canuckInOR]
Loc: South London
As a "C" programmer (and mac user) I prefer the US keyboards to the UK ones, mainly because if I'm in bootcamp I can create "#" characters naturally rather than having to use Ctrl+Alt+3, I hardly ever use the £ sign.
Adrian
#344214 - 13/04/2011 20:12
[Re: canuckInOR]
I always wanted to play with Dvorak. I even set up my favorite free typing tutor, Stamina, to use it, but never got around to it. You can't "play" with dvorak, you commit whole hog. Typing is all about muscle memory, and playing will never get you to that point. I agree. The point you make is exactly why I haven't done much towards it.
#344215 - 13/04/2011 20:36
[Re: canuckInOR]
I think I would probably just start learning Chinese instead, it seems a lot more achievable.
#344217 - 13/04/2011 22:47
[Re: hybrid8]
I think I would probably just start learning Chinese instead, it seems a lot more achievable.  I do have a copy of Windows 3.2 if you need it.
#344218 - 14/04/2011 00:05
[Re: drakino]
I have a copy of Windows 2000 in Traditional Chinese. None of that commie pinko simplified crap...
You're welcome to it.
#344224 - 14/04/2011 08:18
I'm still very happy with my Logitech DiNovo keyboard + mouse combo PgUp/PgDn key cluster's not right. Just to clarify what that means, is this the right order? Yes. Meh... the paint on the key caps doesn't matter, you can set your layout to whatever you like.  As Bruno points out, the UK keyboard actually has different key layout. Relative to a US keyboard, the backslash moves from above Enter to between Left-Shift and Z; the # symbol is on a key next to the Enter key (Shift+3 gets you a £). As a "C" programmer (and mac user) I prefer the US keyboards to the UK ones, mainly because if I'm in bootcamp I can create "#" characters naturally rather than having to use Ctrl+Alt+3 This doesn't make any sense. On a real UK keyboard, # gets its own key.
#344225 - 14/04/2011 09:05
[Re: Roger]
Loc: South London
Yes....but UK mac keyboards don't, infact you won't even see the # symbol anywhere, you have to know that it's on the "3" key. (Alt+3 in Mac OS and Ctrl+Alt+3 in Windows) Hence why as a C programmer I prefer US mac keyboards. Adrian
Edited by sn00p (14/04/2011 09:06)
#344226 - 14/04/2011 09:06
[Re: Roger]
As a "C" programmer (and mac user) I prefer the US keyboards to the UK ones, mainly because if I'm in bootcamp I can create "#" characters naturally rather than having to use Ctrl+Alt+3 This doesn't make any sense. On a real UK keyboard, # gets its own key. It does if you are using a UK Mac keyboard, which doesn't have a dedicated # key (or a key with a # symbol on it at all).
#344227 - 14/04/2011 09:42
[Re: andy]
It does if you are using a UK Mac keyboard, which doesn't have a dedicated # key (or a key with a # symbol on it at all). Wow. That sucks. Does it have double-quote on Shift+2, etc.? I can only find pictures of what look like US mac keyboards.
#344228 - 14/04/2011 09:43
[Re: sn00p]
Hence why as a C programmer I prefer US mac keyboards. Use ??=
#344229 - 14/04/2011 09:54
[Re: Roger]
Loc: South London
Double quote is near the return key shared with the apostrophe. 2 is the @ and euro symbol. Adrian
#344230 - 14/04/2011 11:33
[Re: Roger]
Does it have double-quote on Shift+2, etc.? I can only find pictures of what look like US mac keyboards. Here's a full-sized (wired) UK Mac keyboard. Open the image in a new tab or window to see the full size (~900 pixels wide)  The PgUp cluster is correct and it still has an extra key between the left shift and z, though different glyphs. There are also a number of other changes making this distinctly different than the previously posted UK keyboard. BTW, what are the symbols on the key below the ESC used for?
Edited by hybrid8 (14/04/2011 11:42)
#344231 - 14/04/2011 11:51
[Re: hybrid8]
Those seem to be the 'plus minus' and 'paragraph' symbols. Not used all that frequently. The paragraph symbol I used most frequently in legal documents. The 'plus minus' symbol is used even less.
#344232 - 14/04/2011 12:27
[Re: BartDG]
Since it wasn't (originally) immediately clear, I'm talking about the Mac keyboard below.
To me it would seem like a good move to standardize (at least for the UK) on the US layout with minor keycap changes. For instance in the UK you'd place the £ up top at number along with # - and you'd type them with inverse modifiers compared to a US layout. Shift and Option in Mac OS. Similarly I suppose for the € which requires Shift+Option+2 in the US layout. It can be swapped with ™ which only requires Option.
I really can't stand that janky return/enter key on the Apple UK keyboard.
Edited by hybrid8 (14/04/2011 13:57)
