#346210 - 05/07/2011 14:30 (j)emplode download, MK 1 player
julf
OK, so I guess I should have an empeg mounted in the vehicle for the weekend. As the MK 1 fits the Land Rover from a styling point of view, I want to take that one with me, but... It's been a while since I have uploaded music into it. I guess jemplode on linux doesn't support USB, so I need to get something set up on the "occasional use" windows XP box. Just don't seem to find a download address for either jemplode or the original emplode software...
#346213 - 05/07/2011 14:35 Re: (j)emplode download, MK 1 player [Re: julf]
http://www.empeg.com/downloads
...still works for me.
#346214 - 05/07/2011 16:04 Re: (j)emplode download, MK 1 player [Re: Roger]
jEmplode is mirrored off RioCar.org. I've updated the post the jEmplode link at the top of the page to reflect this.
#346225 - 06/07/2011 03:58 Re: (j)emplode download, MK 1 player [Re: drakino]
julf
Thanks! I assume there is no way to get mp3s from a linux machine to a MK1?
#346229 - 06/07/2011 07:59 Re: (j)emplode download, MK 1 player [Re: julf]
Well, there's serial...
#346230 - 06/07/2011 08:04 Re: (j)emplode download, MK 1 player [Re: Roger]
julf
Ummh, yes... Just quickly tried to compile empegtool on my ubuntu system, but it was missing some header/library files, will look into it at some point...
#346232 - 06/07/2011 10:29 Re: (j)emplode download, MK 1 player [Re: julf]
I suppose you could do it all in a Mk2/Mk2a unit, and after it's all set-up and working, then install the Mk1 .upgrade file over top of it all.
#346238 - 06/07/2011 12:27 Re: (j)emplode download, MK 1 player [Re: mlord]
julf
Well, I can do the basic uploading here at home from the windows box, so if I then need to update stuff (because I forgot essential audio files), I can probably use serial from my linux laptop.
#346254 - 06/07/2011 15:33 Re: (j)emplode download, MK 1 player [Re: julf]
There used to be an Empeg USB driver for Linux. It might even have been in the mainstream kernel. Look under USB serial adaptors, maybe, 'cos that's what it basically was.
Edit: Still there in 2.6.39! The config setting is USB_SERIAL_EMPEG.
#346259 - 06/07/2011 19:20 Re: (j)emplode download, MK 1 player [Re: peter]
julf
Cool!
