Page 2 of 2 < 1 2
#348721 - 02/11/2011 11:17 Re: Error "Bad pump response" occured during stage 0x25 [Re: drakino]
bauble
Ok; I'll try that as soon as I get home tonight.
#348759 - 02/11/2011 22:23 Re: Error "Bad pump response" occured during stage 0x25 [Re: bauble]
bauble
I've tried putting the image on the SSD; I get the same "Bad pump response". :-(
Here's the serial output:
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v508 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Fri Jan 9 16:06:35 EST 2009
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30102546) 16MB DRAM
Command line: mem=16m
Memory: 15000k/16M available (996k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Tuner: loopback=0, ID=-1
show_message("Hijack v508 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004080).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0x0000
ide_data_test: wrote 0xaaaa read 0x0000
ide_data_test: wrote 0x5555 read 0x0000
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:f2
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
#348762 - 02/11/2011 22:39 Re: Error "Bad pump response" occured during stage 0x25 [Re: bauble]
It looks like we are back to the SSD not being detected. Is it plugged into the same spot on the cable it was last time?
Mark, any idea if this is a potential bad IDE header issue where the drive works only as a slave device and not master? Though what I find odd is that things worked when both hard drives were in the system. Maybe a bad cable instead (the crimping issue?)
#348763 - 02/11/2011 22:41 Re: Error "Bad pump response" occured during stage 0x25 [Re: bauble]
bauble
For no good reason, I slaved the Transcend SSD to the smaller (2GB) one (the 2GB was able to load by itself without any issues).
I got a message "Error "Couldn't find pump" occurred during stage 0x25" on the computer; and the RioCar has a message: "abb0.-1 hda: err: stat_timo".
If it helps, here's the serial output from this setup:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
empeg state support initialised 0089/88c1 (save to d0004300).
ide_data_test: wrote 0x0000 read 0x8ea1
ide_data_test: wrote 0xffff read 0x8ea1
ide_data_test: wrote 0xaaaa read 0x8ea1
ide_data_test: wrote 0x5555 read 0x8ea1
hda: SanDisk SDCFH-002G, ATA DISK drive
hda: SanDisk SDCFH-002G, 1918MB w/1kB Cache, CHS=3897/16/63
Partition check:
hda:hda: irq_timo: status=0xf1
show_message("aab0.-1 hda: err: irq_timo")
ide0: reset: failed
[PTBL] [974/64/63] hda1 < hda5 hda6 > hda2 hda3 hda4
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting player
Timezone: EST
hijack: removed menu entry: "Serial Port Assignment"
kftpd: listening on port 21
khttpd: listening on port 80
player.cpp : 385:empeg-car 2.01 2004/07/06.
! tags.cpp : 61:Failed to open tags (0xc0041002).
hda: stat_timo: status=0xf8
show_message("aab0.-1 hda: err: stat_timo")
hda: no DRQ after issuing WRITE
ide0: reset timed-out, status=0x80
hda: stat_timo: status=0x80
hda: drive not ready for command
Restored terminal settings
end_request: I/O error, dev 03:03 (hda), sector 0
Abnormal player termination
Player received SIGINT, user interruption
Starting bash.
end_request: I/O error, dev 03:05 (hda), sector 17694
#348764 - 02/11/2011 22:43 Re: Error "Bad pump response" occured during stage 0x25 [Re: drakino]
bauble
Can it be a problem with the player or the cable if I'm able to use both to successfully set up two conventional drives (one master and one slave)?
#348766 - 02/11/2011 23:18 Re: Error "Bad pump response" occured during stage 0x25 [Re: drakino]
bauble
Just realized I hadn't answered your question; apologies.
Yes, the SSD is on the same spot on the cable; and jumpered as master (well, it was when you posted that question).
#348771 - 03/11/2011 05:03 Re: Error "Bad pump response" occured during stage 0x25 [Re: bauble]
The different permutations helps, though I'm personally out of suggestions. Hopefully Mark can help decode some of the messages in the last boot log you posted, with the SSD as slave and the smaller 2G drive as master. My understanding of it shows that the empeg didn't properly detect the slave (hdb) drive.
#348781 - 03/11/2011 11:44 Re: Error "Bad pump response" occured during stage 0x25 [Re: drakino]
I have no idea what you're doing wrong.
But the hardware appears to be working, though I dunno why the SSD doesn't show up as master when no other drive is connected.
#348821 - 03/11/2011 23:01 Re: Error "Bad pump response" occured during stage 0x25 [Re: mlord]
bauble
Well, phooey. Thanks, everyone. I really appreciate the help.
I'm going to see if I can get a replacement drive (it bothers me that I can't use the drive on the RioCar, another Linux computer, a Windows 7 computer and a Windows XP computer) and see if that makes any difference.
#348828 - 04/11/2011 09:09 Re: Error "Bad pump response" occured during stage 0x25 [Re: bauble]
Hollywood Justin
Last time I got this error it was because the stupid cable was not seated completely into the motherboard. D'OH! Now I know why they hot-glued these cables into place at the factory.
#348829 - 04/11/2011 09:13 Re: Error "Bad pump response" occured during stage 0x25 [Re: Hollywood Justin]
Hollywood Justin
Mark or anyone else, are you aware of or can you foresee any issues with using solid state drives such as a size limit or brands incompatible with your big disk builder image? If it works with an MK2a, I really want an SSD!
#348830 - 04/11/2011 09:20 Re: Error "Bad pump response" occured during stage 0x25 [Re: Hollywood Justin]
Hollywood Justin
What about using a PATA SSD with a 2.5 inch SATA SSD or HDD Drive to IDE 44 Pin IDE adapter? Is there any reason that wouldn't work ('cause the SATA SSD's seem to be much less expensive)?
#348832 - 04/11/2011 11:12 Re: Error "Bad pump response" occured during stage 0x25 [Re: Hollywood Justin]
No, they should all work. If we find one that doesn't, then we'll fix things. smile
#348882 - 04/11/2011 21:04 Re: Error "Bad pump response" occured during stage 0x25 [Re: mlord]
Hollywood Justin
We still get great support from you for this discontinued product - better than some companies' products that are still in production! You are awesome, Mark!
Page 2 of 2 < 1 2
