#349525 - 18/12/2011 12:11 Exterior Cat 6 sockets
Is there such a thing? I want to stick a couple in our back yard
#349527 - 18/12/2011 12:48 Re: Exterior Cat 6 sockets [Re: tahir]
#349528 - 18/12/2011 13:06 Re: Exterior Cat 6 sockets [Re: tahir]
Found this
But why not use a std outdoor electrical box with an rj45 wall plate inside.
#349529 - 18/12/2011 14:30 Re: Exterior Cat 6 sockets [Re: gbeer]
MK make such a thing. (That's a modular enclosure that you then get a Cat5e insert for.)
Not cheap though, i.e. possibly less cheap than wifi-enabling whatever you were going to plug into it...
#349530 - 18/12/2011 14:50 Re: Exterior Cat 6 sockets [Re: peter]
Harsh environment jack which can be mounted in a plain waterproof box.
#349531 - 18/12/2011 18:02 Re: Exterior Cat 6 sockets [Re: gbeer]
It's almost like I've seen that somewhere before ….
#349555 - 20/12/2011 12:57 Re: Exterior Cat 6 sockets [Re: peter]
Yeah, I've never used wireless so no idea how well it works through walls etc. I'm, guessing our walls will be pretty transparent (timber frame; recycled newspaper insulation with OSB one side and wood fibre the other) but I have no real idea.
#349556 - 20/12/2011 12:59 Re: Exterior Cat 6 sockets [Re: gbeer]
You're probably right, and I've found something that does this now. But I should really go wireless (as above) just have no experience of it, always set up home and work networks as fully hard wired.
#349583 - 22/12/2011 22:06 Re: Exterior Cat 6 sockets [Re: tahir]
siberia37
Loc: Tacoma,WA
An outdoor Cat 6 jack would make it much more obvious when your neighbor is stealing your Internet connection.
#349627 - 28/12/2011 13:17 Re: Exterior Cat 6 sockets [Re: siberia37]
smile He'd need a bloody long cable.
