#35264 - 30/07/2001 04:03
mikmod (tracked songs) on Empeg
Loc: Hamburg, Germany
Hi all,
I have successfully compiled libmikmod for Empeg and created a very small dummy player with it.
However, I ran into a few problems: after the first pattern, the sound starts getting distorted. The first pattern plays fine, after that, a sound block seems to be followed by a blank block then again by a filled block etc.
Is this due to a bug in libmikmod or is that related to the player hardware?
Also, would anybody be interested in seeing mikmod ported to the Empeg?
Till
#35265 - 30/07/2001 04:11
Re: mikmod (tracked songs) on Empeg
[Re: tigloo]
Loc: Germany (Ruhrgebiet)
Hi.
from what I know, the hardware is almost 100% unrelated to this problem you experience. This counts for the empegs kernel just as well. It might however be a problem that the kernel does not provide full OSS compatibility (it does limit the blocks send to /dev/audio to be a certain size (4000something bytes or samples, I am not sure about this and would have to check the sources to find out).
I would first look at the player code (your player), perhaps you are (unknowingly) doing something nasty with pointers. If you are sure your player isn't the problem, check the (ported) lib.
AND: I would certainly be interested in a .MOD/.MID capable empeg (especially if that functionality would be in the "official" player software somehow (I would prefer a nice plugin-interface, like it was promised some (long) time ago).
cu,
sven
proud MkII owner (12GB blue/green/smoked, #080000113)
#35266 - 30/07/2001 04:20
[Re: smu]
It seems that the problem is somehow related to the player internal double-buffering of the raw sound data.
I am using just a raw sound device hardwired to a buffer size of 4608 (as stated in various places, I got an error message otherwise anyway :) ). The raw sound device just sends the data to stdout which I pipe to /dev/audio or /dev/dsp.
When the player moves on to the second pattern of any song, it seems to be playing a filled buffer, then an empty (zeroed) buffer, then a filled buffer, etc etc.
The first pattern plays perfectly well though. I don't know what is causing it, I will try an older version of the library to see if it is there, too.
I have been working with MikMod long ago and afaik it only allocates the buffers once, then keeps overwriting it - so there shouldn't be a memory issue or anything.
Till
#35267 - 30/07/2001 05:24
[Re: tigloo]
Hm, I can say that I have it working now.
However, sometimes it seems that little Empeg can't keep up with mixing the sound in real-time. libmikmod is definitely not the fastest mixer around, but, it should work on anything that can play MP3.
Again, would anybody be interested in using mikmod? Also, if so, would anybody be interested in hosting binary & source? I won't have my own page until sometime this autumn, so if there's interest out there...
I'd especially look forward to some input that other people have regarding the current glitches etc.
Till
#35268 - 30/07/2001 05:30
[Re: tigloo]
"Little empeg" is a 233Mhz StrongARM box - if a MOD player takes anything much over 10% CPU time it's certainly having problems with life.
We had some perfectly good 8 channel tracker routines on 8Mhz ARM2 machines ten years ago, using around 30% of the CPU.
#35269 - 30/07/2001 06:03
[Re: rob]
That is what I was wondering about - a while back I did a software mixer in assembler on a 80286 running at 12Mhz, it ran pretty well.
Anyhow, I think I found the problem. When running in polling and not DMA mode, the default code used an usleep() in the main loop to free some spare cycles.
This, in combination with the raw output device, seemed to result in blocks being rendered at the wrong times. Removing the usleep() fixed it, but I still don't really know why this was such a big issue.
Well, player runs smoothly now.
Till
#35270 - 30/07/2001 08:58
[Re: tigloo]
Hi Till.
I could host the files plus a small (part of a) page along with it.
cu,
sven
#35271 - 30/07/2001 10:39
[Re: smu]
It would only be a diff for the libmikmod (hardwiring the buffer size for stdout) and the small player. No real instructions needed. :)
But as you were saying in another post, how about setting up a few Sourceforge projects and linking these together with the existing dev sites?
What would also be very interesting is a knowledge base where everybody could enter information, hints, tips, tricks etc into a central database. That could easily be used for generating a FAQ-like documentation.
Especially, what I needed, as a terrible newbie - step-by-step serial connection and working on Empeg's file system. It's not terribly hard to find out, but it's better to be assured reading that others are doing the same way you do.
Till
#35272 - 30/07/2001 11:01
[Re: tigloo]
The FAQ section of this BBS has got step-by-step serial connection instructions under the "Hyperterminal" subject. For working on the file system, I think I have provided a link to some Linux help documents... ___________
#35273 - 30/07/2001 11:23
I saw that one with Hyperterminal on the mars.org site, it gave me a start, but for some reason the player would _not_ drop to the shell after pressing Q.
Also, I noticed that the DSP seems to go into some sort of idle mode and needs initialization by the default player before you can output sound.
All this info is so widespread across different people's pages that I think the current Empeg hackers out there should join forces. :)
I don't want to criticize here, I think I read most of the active poster's pages (dev. related or not) and am impressed by what people do and have done with the Empeg.
However, this "tie it all together"-point is missing, even though smu seems to start working on that right now with his new page.
The webring is also a good idea (just on a side note), I am familiar with PHP programming and I bet there are existing scripts, that shouldn't be hard at all.
I'll be terribly short with spare time until end of August though, otherwise I would have tried to work something out.
Till
#35274 - 30/07/2001 13:12
[Re: tigloo]
I wasn't referring to the mars.org site. I was talking about this entry in the FAQ forum here on this BBS. In the FAQ it gives two possible reasons this might happen:
1) You haven't installed the developer software onto the empeg.
2) You haven't cycled the power on the empeg.
Also make sure the software is set to the correct terminal settings as illustrated in the screen shot in the FAQ.
The mars.org site was supposed to be this "tie it all together" site. I would still like to see it become that. Unfortunately, it's way behind on updates. I have forgotten who runs it. Is that PaulH's site, too? ___________
#35275 - 30/07/2001 13:19
Ah, _that_ FAQ. Missed that entry, and a very good entry indeed.
As for mars.org, I'd be very willing to help updating it if that is ok with the original owner. Maybe it can then also run a (possible) webring.
Till
#35276 - 30/07/2001 14:17
These were exactly my problems with the mars.org site: Updates weren't made to it since about a year ago. Many many many things happened in the meanwhile, and it is still not updated.I mean, just read the "What's new" section of it. the latest entries that matter for developers are:
Developer's Mailing List 01 Feb 2001 Modified instructions
Demo Code 28 Jul 2000 Added C-64 SID music player
Hardware Mixer Information 30 Mar 2000 New code to toggle the Soft Audio Mute
Nothing happened on the developer mailing list sind about august 2000 (if not longer), so the update on instructions regarding that mailing list is rather useless. So the latest updates on the side were done 12 respectively 15 month ago.
However, I hope this might change. I'm willing to shut down my empeg related infos and instead incorporate these in the empeg.mars.org site. I'm however not willing to spend a hell lot of time on adjusting my infos to the empeg.mars.org layout/design (that I like even less than the one of my own pages).
It seems as if these days, some developers become active in programming for the empeg.
The first thing we should clarify is the way we communicate with each other. It is ineffective and even destructive to use too many different ways. So what should we use? This board or the mailing list or a new mailing list?
The second thing is the way to handle common knowledge (or the knowledge we want to share). We could use empeg.mars.org, we could use *.incase.de (i.e. any host in that domain, might as well be part of my existing website, or a standalone one), we could use the FAQ section of this BBS (micing programming info with user info).
cu,
sven proud MkII owner (12GB blue/ green/smoked, #080000113)
#35277 - 31/07/2001 00:13
[Re: smu]
Usually, at least in the development areas where I am active, there's either a mailing list, a newsgroup or a board. Mailing lists and newsgroups are most common and effective, while a board can do the same (but probably has some disadvantages).
The hassle of registering a newsgroup is too much for a start, so the only alternative would be a mailing list. I wouldn't want to step on anyone's toes and say "we have to have a mailing list no matter what", because this board is well-established and it _works_.
If at all, I'd say a special-interest mailing list for developers only as it exists already and reactivate that one.
On top of that, I'd suggest an IRC channel to hang out and meet, probably with a focus on developing but for everyone else, too. This proved useful many times, you have people to chat with and problem solvers with hints, tips and tricks are always at hand.
Till
#35278 - 31/07/2001 07:58
[Re: tigloo]
Loc: Florida
There is a developers mailing list set up and still working (I believe, as I got a mail from Roger L this morning on it). I haven't seen much traffic on it in a while, though. The addy is [email protected]. I think you can just mail to subscribe to get on the list?
Jason _~= Dearing =~_ "WAY too happy about having #99."
_~= Dearing =~_ Gettin' back into it thanks to slimrio!
#35279 - 31/07/2001 08:41
[Re: Dearing]
Yeah, I just joined that this morning. Apart from my test posting, there's been no activity since last year, according to the archives.
#35280 - 07/08/2001 07:43
[Re: tigloo]
Loc: Near Arnhem, Netherlands
I was just wondering if your player can be downloaded at the moment, still have a bunch of these mod files and I'd love to try it. [email protected]
Reg:1934/Mk1:158-6Blue(sold)/Mk2:380-12Amber
[email protected]
Reg:1934/Mk1:158-Blue(sold)/Mk2:380-Amber(sold)/Mk2a:3273-Blue
#35281 - 07/08/2001 11:35
[Re: wvloon]
Hi.
Till's MOD-player is available through my (still preliminary) website at www-new.incase.de in the empeg/files subtree of the navigation. The URL will change to www.incase.de some day in the not too far future.
cu,
#35282 - 07/08/2001 12:49
[Re: wvloon]
Hi there,
I will soon release a special driver for libmikmod that should work with all versions of MikMod. MikMod's behavior for buffer sizes that are not a power of 2 is unspecified according to the developers (strangely so, I would understand if they'd mean a multiple of 2, but a power of 2...?) so I will create a driver that will put in an extra buffer to satisfy MikMod _and_ Empeg with its "I only like 4608 bytes". :)
Right now, libmikmod 3.1.6 seems to work fine with 4608 bytes, though. (binary is included)
Till
#35283 - 07/08/2001 16:42
[Re: tigloo]
Have you tried running mikmod through dd? You can tell dd to reblock, with "obs=4608".
#35284 - 08/08/2001 03:34
[Re: altman]
No,
I did not try that yet. Good idea actually. However, I don't even like having to use the stdout driver and piping that to /dev/audio... sending the sound output to various shell utilities looks pretty dirty to me.
Also, as Empeg is a full-fledged sound device, why not create a full-fledged driver for it...
Till
#35285 - 08/08/2001 09:59
[Re: tigloo]
John (new john) has fixed the 4608 byte limitation in the sound driver for the 2.4 kernel on an upcoming product; this will hopefully find its way back into the v2.0 release.
#35286 - 08/12/2001 14:22
[Re: altman]
Just dug up this old thread and noticed there was talk of removing the 4608 byte limitation... Any chance in reviving this request for a future 2.x build?
#35287 - 09/12/2001 15:12
[Re: tonyc]
Loc: the states
It will be interesting to get this going. Maybe we can
talk the devs into supporting mod formats in a later version
if we get it up and running well.
Ed
When I shoot MY super-computer, the bullets
really DO bounce off. What about yours?
