#353054 - 05/07/2012 11:16 Diagnosing router failure
How can I diagnose an intermittent router failure in a remote office?
It's a Draytek Vigor 2820, the only way I can tell it's stopped working is when they ring to tell me they can't dial in. On site diagnostics (asking users what lights are showing) show that the router has lost it's ADSL connection which means that I can't connect to it externally. Reboots do not fix the problem. As soon as they plug their spare router in it works straight away, problem is that it doesn't do VPN.
If left for a couple of days and plugged back in it works fine.
Any ideas?
#353055 - 05/07/2012 11:47 Re: Diagnosing router failure [Re: tahir]
Originally Posted By: tahir
Any ideas?
eBay
He takes PayPal, free international shipping...
Depends how much your time and your client's time is worth, I guess.
#353056 - 05/07/2012 12:30 Re: Diagnosing router failure [Re: tanstaafl.]
I'm with Doug, sounds like hardware on its way out. My 2820 also failed on me, started giving very high latency when routing.
So much for my theory of spending more money = longer life hardware frown
I'm not back to a two box solution, with my old Thomson TG585n as a modem (as it was useless as a router/AP) and an ASUS RT-N66U doing the routing with Tomato.
Which reminds me, must start a thread discussing my woes with Tomato frown
#353059 - 05/07/2012 12:51 Re: Diagnosing router failure [Re: andy]
Yeah, agree with that frown
New router ordered, I am the client and I don't have the time to spend on this.
#353060 - 05/07/2012 18:27 Re: Diagnosing router failure [Re: andy]
It's a factor, but the environmental and usage factors are probably just as important.
And these things can just go bad...
#353061 - 05/07/2012 19:03 Re: Diagnosing router failure [Re: andy]
More expensive usually means better warranty and support, though. Of course, a move from "nonexistent" to "miserable" isn't necessarily much of a step up.
#353062 - 05/07/2012 19:43 Re: Diagnosing router failure [Re: wfaulk]
One of the reasons I run Apple routers is that Applecare on a computer will extend to cover the router as well. They even extend coverage to any Apple router bought two years prior to buying Applecare, making the maximum warranty period 5 years.
#353071 - 06/07/2012 13:04 Re: Diagnosing router failure [Re: drakino]
Yeah, problem with warranty is mostly that they make you do all sorts of pointless diagnostics on the thing before issuing an RMA. It's easier to just buy a new one.
I have just upgraded the FW to see if that cures it but after that it'll be new router time
#353072 - 06/07/2012 13:26 Re: Diagnosing router failure [Re: tahir]
I've got 50p says it's blown capacitors.
#353074 - 06/07/2012 14:02 Re: Diagnosing router failure [Re: Roger]
Do you want me to send it to you so you can prove that? wink
