#35323 - 30/07/2001 11:49 custom init
crazymelki
Loc: Switzerland
Hello,
I am going to upgrade my MK2 with a second HD. Can someone have a look on my custom init and tell me if there is some additional command needed?
#!/bin/sh
PATH=.:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/sbin:/empeg/bin
PS1=empeg:\\w\\$
/bin/mount -n -o nocheck,rw /proc
/bin/mount -n -o nocheck,ro /dev/hda4 /drive0
/bin/mount -n -o nocheck,ro /dev/hdc4 /drive1
cd /usr/local/displayserver
./displayserver -noauth
/usr/local/bin/stupid-ftpd-arm -f /usr/local/etc/stupid-ftpd.conf
cd /
./empanim 0 122 < anim.ema
/bin/timed &
while [ 1 ] ; do
/drive0/var/pick_list
echo "Press q now to terminate to a shell prompt."
echo
/drive0/var/getkey q && /bin/bash
echo Running Player...
/empeg/bin/player
done
My Kernel hacks is already for 2 disks!
Thanks in advance!
CrazyMelki
crazymelki.com
#35324 - 30/07/2001 13:40 Re: custom init [Re: crazymelki]
Those mount commands are the same ones that I'm using on my player for two disks, should be OK.
You're using the RESERVECACHE parameter in your config.ini, right? Whenever you load Bash as part of your init, you need it.
#35325 - 30/07/2001 14:14 Re: custom init [Re: tfabris]
crazymelki
Loc: Switzerland
Tony,
Thanks for checking my init.
I will have a look! I really don't know! But I read your Info and will check it out. If it's not present, then I will modify it!
CrazyMelki
crazymelki.com
#35326 - 31/07/2001 10:11 Re: custom init [Re: tfabris]
crazymelki
Loc: Switzerland
Tony,
I did just add this two lines in the config.ini!
[startup]
reservecache=12
Now I am ready to upgrade with the second HDD form 20GB (1 x 20) to 40GB (2 x 20). I have also my hot melt glue pistole ready ;-)
Thanks.....
CrazyMelki
crazymelki.com
#35327 - 08/08/2001 12:46 Re: custom init [Re: tfabris]
crazymelki
Loc: Switzerland
Hello Tony,
I did successfull install the second HDD! Thanks for the FAQ documentation to your guys! (Tony, Dionysus, DMoore, Rob Kit and Mac)
The only thing I had to reinstall was the zImage.voladj.clock.irhack hack!
But after that everthing is working well!
bye
CrazyMelki
crazymelki.com
