#354373 - 22/08/2012 23:33 Newbie SMB question
When trying to connect to a shared folder on a windows 7 or xp computer from a MFP (copier/scanner/printer) why would I be able to connect to it using the hosts IP address but not computer name?
I see some computers I can use the computer name and some will only work with the IP address and I don't know why.
#354375 - 23/08/2012 01:49 Re: Newbie SMB question [Re: msaeger]
Do you need to enable netbios over TCP/IP on your client machines?
Do you run a DNS server?
#354377 - 23/08/2012 06:37 Re: Newbie SMB question [Re: JBjorgen]
Or a WINS server? DNS is the right answer, though.
#354404 - 23/08/2012 23:56 Re: Newbie SMB question [Re: Roger]
The last example of this I encountered was a workgroup no server using a linksys type router type thing.
They had the linksys address for the gateway and the dns.
I could connect between computers using the computer name but I can't connect to a computer from the MFP using a computer name.
#354413 - 24/08/2012 04:15 Re: Newbie SMB question [Re: msaeger]
StigOE
I read yesterday that linksys on some of their routers have exactly that problem. The router use itself as the first DNS and for some reason manage to get a wrong IP-address for some domain names. I don't know if that is the same problem encountered here though.
#354426 - 24/08/2012 12:21 Re: Newbie SMB question [Re: msaeger]
Most consumer routers have terrible DNS support. They ought to publish DHCP leases into the DNS server, but they rarely seem to do this reliably. Which is why I use OpenWRT and run a full-blown BIND installation.
#354429 - 24/08/2012 12:27 Re: Newbie SMB question [Re: msaeger]
Your copier/scanner/printer should have a field where you can indicate what the DNS/WINS servers are in your network. In most cases, that's enough to address the issue. If you already did that, then such DNS/WINS servers are not correctly mapping IPs to Hostnames.
