#354603 - 05/09/2012 02:19 Monitor with dimmable backlight?
Hi, well, I've wasted hours over days looking for this, and it seems for any question, someone here knows the answer... smile
I'm looking for a monitor, preferable 24" 1920x1200, with a dimmable backlight. Dimmable like every laptop ever made.
Do these even exist? The room I work in is not bright even in the day, and I tend to work well into the night. My current monitors are blinding.
I've found only one model, but it's like $1700 usd, I'd like to find something much more reasonable.
Thanks!
#354604 - 05/09/2012 03:15 Re: Monitor with dimmable backlight? [Re: larry818]
Is this dimmable backlight somehow different to the brightness control ?
#354605 - 05/09/2012 05:11 Re: Monitor with dimmable backlight? [Re: andy]
Yep, the brightness and contrast fiddle with the video settings, if you dim that way, it munges up the image.
#354606 - 05/09/2012 12:24 Re: Monitor with dimmable backlight? [Re: larry818]
The only ones I know definitively that support this are Apple's displays.
#354608 - 05/09/2012 13:57 Re: Monitor with dimmable backlight? [Re: hybrid8]
I'll look at those then, thanks!
#354609 - 05/09/2012 14:41 Re: Monitor with dimmable backlight? [Re: larry818]
On a Windows machine you'll have to install Apple's control panel to adjust the brightness, as the display doesn't have any buttons itself.
https://discussions.apple.com/message/13135250?messageID=13135250#13135250?messageID=13135250
Isn't the backlight on Dell's IPS LED-backlit LCD monitors adjustable?
