#355793 - 19/10/2012 11:15 HDanywhere
I'm just about order the Multiroom+ 4x4 HDBaseT, lots of positive reviews about and they seem to be good at support. Any compelling reason not to buy? Is there another product I should be looking at?
#355798 - 20/10/2012 00:04 Re: HDanywhere [Re: tahir]
Looks pretty neat. The only thing I see going against it is that you need 4 ethernet (well one for each remote device) all the way to the HDanywhere and all your sources (which have to be in the same place - not a big deal since that'd be common). i.e. you can't put it in a server cupboard under the stairs or something like that unless that's where you keep all your sources.
I presume that's OK with you?
Edit: I'm guessing they're kinda expensive too?
Edited by Shonky (20/10/2012 00:13)
#355800 - 20/10/2012 15:18 Re: HDanywhere [Re: Shonky]
8x8 matrix + full extender kit is £6,500. The 4x4 kit is little more affordable at £1,500. If you just want a 4x4 matrix then that's only £350.
Looks like quite a nice product.
#355809 - 21/10/2012 08:00 Re: HDanywhere [Re: andym]
Sources will be located alongside the server, the house is fully wired. It's definitely expensive but I couldn't find anything cheaper. OK I'll go with it thanks.
#355812 - 21/10/2012 08:32 Re: HDanywhere [Re: tahir]
Right but you need four separate ethernet runs where the matrix box lives. If you've wired your new place with multiple runs you're OK to go.
I don't think I would have ever thought to run more than a couple of connections to each location (and in particular to where most of my AV gear lives). I'll certainly try to remember that in the future though since I can see a future with something like this.
Edited by Shonky (21/10/2012 08:33)
#355813 - 21/10/2012 08:36 Re: HDanywhere [Re: Shonky]
The hdanywhere box will live in our plant room, this is where the satellite and terrestrial TV, internet etc all come in, every cat5 cable is routed back to there. I think there are around 40 runs altogether.
