#355849 - 22/10/2012 10:37 Error 'There isn't a file with FID 2 on this device'
Just had the error 'There isn't a file with FID 2 on this device' come up and am trying to figure out whether this is a complete rebuild error or something simple to sort, but a search of the forum returns nothing.
Bit of background - was deleting some tracks and adding others, and when the empeg rebooted it didn't have the same name in jemplode (had changed to empegcar) and all the tracks had vanished.
Anyone have some insight into this error?
Edited by frog51 (22/10/2012 10:41)
#355854 - 22/10/2012 11:36 Re: Error 'There isn't a file with FID 2 on this device' [Re: frog51]
Top of my head, I think ID 2 is config.ini.
#355855 - 22/10/2012 11:38 Re: Error 'There isn't a file with FID 2 on this device' [Re: Roger]
Nope:
/* Predefined fids */
#define FID_VERSION		0
#define FID_ID			1
#define FID_TAGINDEX		2
#define FID_STATICDATABASE     	3
#define FID_DYNAMICDATABASE	4
#define FID_PLAYLISTDATABASE	5
#define FID_CONFIGFILE		6
#define FID_PLAYERTYPE		7
#define FID_VISUALLIST		8
#define FID_EXTRADB		9
#355857 - 22/10/2012 12:10 Re: Error 'There isn't a file with FID 2 on this device' [Re: Roger]
Sounds like it ought to be fixable by deleting any/all existing database files and rebuilding the database afterward. ?
#355867 - 22/10/2012 15:00 Re: Error 'There isn't a file with FID 2 on this device' [Re: mlord]
Yeah:
# rwm
# rm /empeg/var/tags
# rm /empeg/var/database
# rm /empeg/var/database3
# rm /empeg/var/playlists
Restart player.
#355868 - 22/10/2012 15:31 Re: Error 'There isn't a file with FID 2 on this device' [Re: Roger]
Interestingly, when I do this each of those commands returns a file not found error, and in fact the only thing in /empeg/var is a /tmp so something has obviously broken.
As I'm now seeing an i2c: Failed to receive ACK for data, I'm guessing I have a bigger problem.
Think I may check all connections, and possibly rebuild!
Edited by frog51 (22/10/2012 15:32)
#355869 - 22/10/2012 17:27 Re: Error 'There isn't a file with FID 2 on this device' [Re: frog51]
Ahhh - a fsck gives me a whole load of block bitmap differences, so am fixing /dev/hda4 now...
It fixed quite quickly
/dev/hdc4 is giving me so many issues I just have a screen full of flowing fsck output :-(
Edited by frog51 (22/10/2012 17:37)
#355871 - 22/10/2012 19:44 Re: Error 'There isn't a file with FID 2 on this device' [Re: frog51]
Dammit - after an hour it bombed out and now no init found - kernel panic.
Guess I will be popping on a builder image and starting from scratch...
