#3686 - 12/02/2000 22:58
Drive Height Limitation Again?
What was the limit on the drive height? I'm thinking of snagging an IBM DTCA-24090 which is 12.7mm high. Will this fit in the second slot in my Mk1? -- Tony Fabris -- Empeg #144 -- Caution: Do not look into laser with remaining good eye.
#3687 - 13/02/2000 05:53
Re: Drive Height Limitation Again?
Loc: Meije, Netherlands
Toni, I'm running out of space too and considering to break the seals and add an additional drive. The one that you consider is 4GB, isn't it? Shouldn't be too difficult, when I read djmoore's guidelines. I'm tagging onto your message to post my own queries. Maybe that Hugo or anyone else can help:
1) I've read about a 18GB Toshiba drive (MK-1814GAV), but cannot find a supplier / price. Do they exist in real life? Would it fir inside the empeg?
2) On IBM drives: I've seen their 10GB (Travelstart 18GT models - DARA218000 and DARA215000??) and 25GB models (Travelstar 25GS - model DARA22500), but remember the Empeg warnings that (some??) IBM drives would be a difficult fit.
What should I do? I need an extra drive (donot want to prune the current playlists) and would at leadt need 10GB. What is the best (easy installation) option?? Henno
Henno # 00120
Henno
mk2 [orange]6 [/orange]nr 6
#3688 - 13/02/2000 10:18
[Re: Henno]
Loc: San Francisco, CA
take a look at the toshiba 10gb drives; they're cheap! (I picked 2 up for around 500$ total..) Model#MK1011GAV -mark
#3689 - 13/02/2000 10:44
[Re: dionysus]
Where did you find these (Toshiba 1011GAV -10.5 GB)? Over here (Europe) they are almost US$ 350 each (that's after discount; excl 17.5% sales tax)
Henno
Henno # 00120
Henno
#3690 - 13/02/2000 11:00
[Re: Henno]
...I purchased mine from PC Progress - it actually came to $528 (for two) after shipping, and that was back in december.. It doesn't look like they carry the 10gb unit anymore, but they seem to have a 12gb toshiba (8.5mm) for $289 ...Here's a direct list of their notebook drivesAlso, try going to pricewatch.com, and checking their "notebook drives" category... -mark ...proud to have one of the first Mark I units
#3691 - 13/02/2000 11:16
[Re: Henno]
Loc: St. Louis, MO
Yes they do exist. I called a computer store that I used to work for and they are able to get them so I imagine that just about anyplace can.
#3692 - 14/02/2000 00:13
This was discussed previously, and if I remember correctly, half an inch is too much. While the disk would physicaly fit, it would not have enough room to vibrate, defying the purpose of shock mounts. (I think Toshibas Empeg uses are 9.5mm high.)
Dragi "Bonzi" Raos Zagreb, Croatia #5196
Dragi "Bonzi" Raos
Q#5196
MkII #080000376, 18GB green
MkIIa #040103247, 60GB blue
#3693 - 14/02/2000 01:12
[Re: bonzi]
Dragi --
Actually, Rob said the maximum height was 14 mm. Below is his post responding to a similar question some time ago...
The width and length should be totally standard, but the height varies from model to model. The highest drive you can fit is 14mm. To put this in perspective, the 10Gb Toshiba drives that we fit are 12.5mm high and the 25Gb IBM TravelStar drives are 17.5mm (too big for many laptops as well as the empeg).
This would suggest that a 12.7mm IBM drive would, indeed, fit.
#3694 - 14/02/2000 01:30
Toni, Drive height limitations were discussed last year in the 'General Discussion' discussions on the '50GB unit' subject. Rob commented (Mon Sep 27 17:05:09 1999) that IBM Travelstars were too high: The width and length should be totally standard, but the height varies from model to model. The highest drive you can fit is 14mm. To put this in perspective, the 10Gb Toshiba drives that we fit are 12.5mm high and the 25Gb IBM TravelStar drives are 17.5mm (too big for many laptops as well as the empeg).Your 24090 is a Travelstar, but IBM lists its height as 12.7mm. Which is just a hair taller than the 12.5mm Toshiba MK-6409 that came with my 6.4GB empeg. Well within the 14mm limit I would say, just like the IBM 18GT models (DARA 215000 and 218000 which hold 15GB and 18GB) and which are also listed as 12.7 mm tall. I want a (large  ) second drive too. First on my list is the Toshiba 1814GAV (18 GB; 12.5 mm); then the two IBMs of 18GB and 15GB. Last resort (of if I can't afford any of these really big babies; I'd wished that European prices were as low as in the US) the Toshiba 1011GAV that is used in moore's installation guidelines. Rob/Hugo, any comments / experiences ? Henno # 00120
Henno
#3695 - 14/02/2000 02:47
Actually, Rob said the maximum height was 14 mm.Ah, senility is such an interesting thing: one learns something new all the time...  (I could have bet I remembered correctly; I should have known better...) Sorry for causing confusion. Cheers! Dragi "Bonzi" Raos Zagreb, Croatia #5196
Dragi "Bonzi" Raos
Q#5196
#3696 - 16/02/2000 12:00
[Re: Henno]
12.5/12.7mm drives are ok. What won't fit are the 25Gb 17mm IBMs!
#3697 - 16/02/2000 12:02
[Re: Henno]
Toshiba 18's do exist, but are hard to get hold of. The IBM 18's came out earlier, and we've played with them already - again, they're expensive.
You might also try Fujitsu, who do a 12.5mm 18gb.
