Page 4 of 4 < 1 2 3 4
#372019 - 25/05/2019 23:14 Re: Replacement SSD? [Re: mlord]
Still no love. Played music and everything, just didn't survive a power cycle.
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux...................................... done, booting the kern
el.
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v524 ([email protected]) (gcc version
2.95.3 20010315 (release)) #7 Sat May 25 07:54:55 EDT 2019
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 10101536) 16MB DRAM
Command line: mem=16m
Memory: 14992k/16M available (1000k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Tuner: loopback=0, ID=-1
show_message("Hijack v524+ by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005600).
empeg RDS driver initialised
RAM disk driver initialized:  16 RAM disks of 4096K size
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0x0000
ide_data_test: wrote 0xaaaa read 0x0000
ide_data_test: wrote 0x5555 read 0x0000
hda: SINTECHI HighSpeed SD to CF Adapter V1., [sdcard remap 0->1] ATA DISK drive
hda: SINTECHI HighSpeed SD to CF Adapter V1., 29664MB w/8kB Cache, CHS=60269/16/
63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:0
0
Partition check:
 hda: unknown partition table
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...attempt to access beyond end of device
03:05: rw=0, want=2, limit=0
dev 03:05 blksize=1024 blocknr=1 sector=2 size=1024 count=1
EXT2-fs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 03:05
#372020 - 25/05/2019 23:20 Re: Replacement SSD? [Re: Roger]
Mmmm.. I don't see the message indicating that the kernel detected the SINTECHI reader. I can force it on.. gimme a sec.
Blind. As. A. Bat.
I guess I'll have a better look at it either at The Meet, or after The Meet.
Cheers.
Edited by mlord (25/05/2019 23:23)
#372021 - 26/05/2019 00:41 Re: Replacement SSD? [Re: Roger]
Sounds good. Thanks!
#372045 - 07/06/2019 20:29 Re: Replacement SSD? [Re: mlord]
.. the SINTECHI reader ..
Roger was kind enough to pick up a SINTECHI adapter for me in the UK, and I have been playing with it here for an hour or so now.
It seems to behave just fine with a 4GB SD-Card, and with a 16GB SD-Card, but not with the 64GB card here. I don't have anything in between 16 and 64GB to try it on, but I suspect some kind of capacity limitation.
EDIT: The onboard chip is labelled as FC1307, but also has a letter A literally scratched onto the surface after the FC1307 part. So it is either a FC1307A, or a counterfeit of some sort.
If anyone at the Meet has a 32GB card for me to try, I'll report back on that later as well.
Edited by mlord (07/06/2019 21:01)
#372048 - 08/06/2019 03:33 Re: Replacement SSD? [Re: Roger]
Can't be a size limitation because it failed to survive a reboot with a 1gb card that I built. It must be some other factor. That said, if I can get a confirmed card that it works with, I'm happy to pick up a different card.
#372049 - 08/06/2019 07:21 Re: Replacement SSD? [Re: Roger]
The chip on mine is marketed as a SD-CF adapter, so pretty much the same kind of thing that might be found in some of the various SD-CF-Card adapters also found on Amazon. There's another chip that also is/was pretty common on these, as can be seen in some of the product photos on A.
Which chip did you get?
#372053 - 09/06/2019 00:43 Re: Replacement SSD? [Re: Roger]
It's at the office, I'll have to wait until Monday to check.
