#371836 - 26/03/2019 13:10 Hijack: restart player without remounting disks read-only?
With Hijack, I can issue SITE RW to remount the disks read-write. But...
If I issue SITE REBOOT over FTP, the disks are remounted read-only. I'd like the player to have the opportunity to rebuild (and write) the database files.
I've also tried SITE EXEC echo reboot > /proc/empeg_notify. Same outcome.
Is there a way to mount the disks read-write and restart the player app without messing around with a serial connection?
Also: did the SITE command ever get implemented over HTTP, rather than FTP?
#371841 - 27/03/2019 19:49 Re: Hijack: restart player without remounting disks read-only? [Re: Roger]
There is a way to do EXEC over http -- I'll have to look it up later. But perhaps simpler than much of this is to use telnet rather than ftp ?
Hijack has a telnet server.
#371842 - 27/03/2019 20:24 Re: Hijack: restart player without remounting disks read-only? [Re: mlord]
Elixir doesn't have a telnet client smile
#371843 - 27/03/2019 20:31 Re: Hijack: restart player without remounting disks read-only? [Re: Roger]
I looked through the source code, and it appears my recollection was incorrect: no obvious EXEC over http.
Perhaps I should just implement a "restart player" or "restart player in r/w" option native to Hijack..
On a train hundreds of miles from my empegs at the moment.
#371846 - 27/03/2019 21:09 Re: Hijack: restart player without remounting disks read-only? [Re: Roger]
Rather than hoping I'll remember to do something about this, another method is to write a shell script to do the steps required, FTP that to the player, and run it (script) using SITE EXEC.
#371849 - 27/03/2019 21:32 Re: Hijack: restart player without remounting disks read-only? [Re: mlord]
The problem I have is that I can't figure out how to restart the player binary from there anyway. I tried killing pid 1, but bad things happened -- I apparently ended up with two copies of the player running, which was very confusing.
Unless I can send keypresses as if over serial...?
#371850 - 27/03/2019 21:59 Re: Hijack: restart player without remounting disks read-only? [Re: Roger]
You can send keypresses over http:
http://my.empeg/?BUTTON=r
Or (I think) over FTP:
SITE BUTTON r
Or something like that. smile
