#37265 - 27/08/2001 21:46 MK1 wiring harness question
hello
I am making a new mk1 harness and I just need to know which wire on the serial cable is the +12V line. the pinout on the all things empeg site lists pin one as having the +12v and the +12v line from the serial but doesn't say what color wire that is
I am guessing it is the green because it is the only one left but I want to be sure
also where should I connect the shield on the serial cable to ? the GND on pin 8 ?
thanks
matt
matt
32Gig MK2 In 2001 VW Golf TDI
#37266 - 28/08/2001 02:37 Re: MK1 wiring harness question [Re: msaeger]
Pin 4 (DTR) is +12v, ground is pin 5. Not sure on the colours.
#37267 - 28/08/2001 06:18 Re: MK1 wiring harness question [Re: altman]
thanks pin 4 on the serial connector is the green wire
now I just need to know what pin on the docking connector to connect the gnd on the serial cable to
