#374254 - 16/02/2024 13:53 Dead PC maybe?
My work PC seems to have died but not in a way that I've ever encountered:
Nothing at all in terms of Video output
both HDDs seem to spin up
LAN card lights blinking
I assumed this meant that the VGA chip (on board) had died so I bought and installed a new graphics card
PC seems to boot up fine, HDDs spin up, CPU fan spins up but still no video
I've tried different monitors, connection types and cables
It's only a crappy PC but it seems a strange way to die
Any ideas?
#374255 - 17/02/2024 00:25 Re: Dead PC maybe? [Re: tahir]
If you haven't done this already:
- Pull every card out of the computer, if any. Every. Single. One.
- Remove all keyboards, mice, sound devices, USB devices, everything.
- Remove all RAM sticks.
- Disconnect hard disks from the motherboard.
- Plug only the VGA cable into the onboard VGA port. Nothing else is plugged into the computer except the power cord and the VGA cable.
- Then, see if you get any video output when you turn it on. The computer won't "work" but you should at least get a BIOS message on the screen complaining about a lack of RAM.
If you get any video output, then power off, begin adding items back in one at a time, and power on again with each item, until you reproduce the problem with a single specific item.
#374256 - 20/02/2024 15:13 Re: Dead PC maybe? [Re: tahir]
Will try that
#374257 - 22/02/2024 11:07 Re: Dead PC maybe? [Re: tahir]
Haven't got round to testing but I bought a new HP PC to replace it, the thing started randomly locking and screen would go crazy, I spoke to support they reckon it's a dodgy DIMM!
#374258 - 23/02/2024 03:47 Re: Dead PC maybe? [Re: tahir]
Indeed, could be. Did you transfer the DIMMs from the old PC to the new replacement PC?
The support tech probably already suggested that you use Memtest86 to check and be sure.
#374259 - 23/02/2024 04:35 Re: Dead PC maybe? [Re: tahir]
In addition to what Tony suggested, while you have all the cards out and everything disconnected from the mainboard, if it has a removable BIOS battery, you can try popping it out for a while and then put it back. Occasionally that does the trick.
#374260 - 26/02/2024 14:05 Re: Dead PC maybe? [Re: tahir]
I have had a battery fail in the past, didn't think of that at all. I have a spare here, will test it when I have a moment.
He didn't ask me to run memtest, he was quite certain that it was a memory issue based on the beeps. I had ordered 2 x 32gb DIMMs for upgrade anyway, I installed them last Thursday it's been running fine since.
#374261 - 27/02/2024 18:53 Re: Dead PC maybe? [Re: tahir]
I don't see how you can get by with only 64GB of RAM. Why, MY computer has fully one-quarter of that amount! sick
I'm jealous! Actually, no, the most demanding application I ever run is Quake 3 Arena. It's a struggle, but I get by. Somehow...
#374262 - 28/02/2024 06:51 Re: Dead PC maybe? [Re: tahir]
RAM is pretty cheap at the moment…
#374263 - 28/02/2024 16:32 Re: Dead PC maybe? [Re: tahir]
I've always managed to get by with 8gb but am currently doing a lot of stuff on quite large files in Photoshop, I'm hoping this will improve things
#374384 - 11/06/2024 16:31 Re: Dead PC maybe? [Re: tahir]
It was the motherboard, found a replacement MB on eBay for £30
#374388 - 18/06/2024 13:18 Re: Dead PC maybe? [Re: tahir]
16GB sure feels like the minimum for Windows/Mac these days... And like Andy says, it's so cheap (except in Apple land where it's ridiculously expensive)
