#374329 - 15/04/2024 14:22 Wish my PC hadn't died!
New HP PC on Win 11 has an issue where the taskbar is not refreshing, the most visible manifestation being the time doesn't update (it also means that if close an app then you're not necessarily going to get the window you think when you click it in the taskbar).
Tried all the fixes I can find on the wwww, has anyone had this and successfully fixed it?
#374330 - 15/04/2024 15:48 Re: Wish my PC hadn't died! [Re: tahir]
First I've heard of this one. What happens when you float your mouse above a taskbar item?
#374331 - 15/04/2024 15:56 Re: Wish my PC hadn't died! [Re: tahir]
It'll relate to whatever item was there, not the current one
#374385 - 11/06/2024 16:32 Re: Wish my PC hadn't died! [Re: tahir]
It seems to be related to my PC not correctly joined to the domain. It seems OK now (last week or so)
#374386 - 18/06/2024 12:01 Re: Wish my PC hadn't died! [Re: tahir]
Nope, still got it. PC shows 10:10, DC shows 12:57
Flipping thing
#374387 - 18/06/2024 13:16 Re: Wish my PC hadn't died! [Re: tahir]
I'd imagine this is a bug in the DWM or Explorer. Have you tried seeing what happens when you go to task manager and kill the Desktop Window Manager or explorer, then run it again? (although I'm actually not sure how to run apps via task manager anymore - darn Windows 11)
Edited by Dignan (18/06/2024 13:19)
#374389 - 18/06/2024 15:31 Re: Wish my PC hadn't died! [Re: tahir]
Originally Posted By: tahir
New HP PC on Win 11
Did you repave it with a fresh Windows install, or is this the default, manufacturer-installed crapfest?
If the latter, I'd put good money on that being your problem. There's some HP-installed crap that's screwing up the taskbar.
#374390 - 18/06/2024 15:31 Re: Wish my PC hadn't died! [Re: tahir]
Restarting Explorer has fixed it (yes Windows 11 is a pain), so a bug in one of the most import components of Windows. Crazy.
#374391 - 18/06/2024 15:32 Re: Wish my PC hadn't died! [Re: Roger]
New HP PC on Win 11
Default HP install, I'll see what's installed that I can remove
#374392 - 18/06/2024 15:34 Re: Wish my PC hadn't died! [Re: tahir]
Wow, there's a LOT of HP shit installed
#374401 - 20/06/2024 14:06 Re: Wish my PC hadn't died! [Re: tahir]
Classic HP. Take it all out.
I've been rocking a Framework laptop for about a year now and I love it. No crapware other than Windows 11 its self!
#374407 - 19/07/2024 16:21 Re: Wish my PC hadn't died! [Re: tahir]
So, taskbar issue seems to be fixed, yay!
But I've got a new issue (seems to be quite common), clipboard stops working after a while. Needs reboot or logoff to fix.
I've tried every fix I can find on the internet but no joy.
MS problem I think as loads of people seem to have the issue on a variety of machines.
Poxy stupid machine
#374409 - 26/07/2024 16:46 Re: Wish my PC hadn't died! [Re: tahir]
No it's not!!
#374418 - 26/08/2024 10:01 Re: Wish my PC hadn't died! [Re: tahir]
I’ve got a new Windows 11 issue in recent weeks. The Start Menu loads completely blank, just an empty dark grey rectangle.
Opening and closing it a few times fixed it.
I find this representative of the basic functionality of Windows nowadays. The search still doesn’t reliably present local applications as prominent results (or even show them at all in some cases) when you are typing the actual name of the app.
It possibly only happens using RDP, but that doesn’t let Microsoft off, I’m using their RDP client to connect to their OS.
Mind you, searching for installed apps is one areas Apple needs a kick up the arse on. It is insane that iOS doesn’t use the metadata it has on the app to help find apps.
An example, I have an app for the Bluetooth level sensor on the gas bottle on our campervan. But I can never remember what the app is called. You’d imagine searching for “gas” or “sensor” or “Bluetooth” might find it, but no.
The app is called Tank and the company name is Mopeka and as far as am aware those are the only two search terms that will find it. So I now have a Shortcut named “Van gas” that launches the app, so I can search for “gas” or “Van”. I have this for a few rarely used apps now.
#374419 - 27/08/2024 09:54 Re: Wish my PC hadn't died! [Re: tahir]
The finding apps things isn't specific to RDP
#374721 - 06/08/2025 08:59 Re: Wish my PC hadn't died! [Re: tahir]
Effing PC, randomly won't come out of sleep. This has been pretty much since I bought it. Used to be every couple of weeks, at the moment it's every day!
I've just set power options to not let it go into sleep, which seems ridiculous on a new HP PC with Win 11. I'm glad most of the office is on thin clients (which I've hacked to standardise on Mint).
#374722 - 06/08/2025 13:41 Re: Wish my PC hadn't died! [Re: andy]
… one areas Apple needs a kick up the arse on. It is insane that iOS doesn’t use the metadata it has on the app to help find apps.
An example ..
Agreed. Apple has always required the user to know the ‘code name’ for the app they wish to use.
Code names are fine when an app is in development and you want to keep the app purpose secret from the outside world. But app names are often non-guessable if you know the functionality but not the actual name of the app you want to launch.
Shortcuts are a useful hack to add a more memorable or findable app name, but fall short of being a complete solution. I often go hunting for a rarely used app on my Mac (or iDevice) and spend time scrolling along until I see the app and recognize that is the app I am looking for.
I do use app grouping on iPad and iPhone, which helps a bit.
