#374450 - 17/10/2024 18:47 Odd din connector
I have a strange din connector, it's the same size as a 5-pin din (DMX or XLR sized), but it has a notch in the side like a mini-din S-Video connector.
Has anyone seen this available?
[img]https://scontent-lax3-1.xx.fbcdn.net/v/t...amp;oe=67172B14[/img]
Thanks!
#374451 - 17/10/2024 21:20 Re: Odd din connector [Re: larry818]
#374452 - 20/10/2024 10:24 Re: Odd din connector [Re: larry818]
Yes, that's the mini-din. I need a regular sized din version.
#374453 - 20/10/2024 13:59 Re: Odd din connector [Re: larry818]
So perhaps one of these: https://www.ebay.com/itm/284738449633
I am assuming you are hunting for the male connector, right? So it doesn't actually need to have a notch. You could even take that 5-pin one, and snip away the middle 5th pin.
#374454 - 22/10/2024 17:17 Re: Odd din connector [Re: larry818]
Thanks! It is the same pin spacing as the 5 pin, and I did make one with the middle pin amputated, but I also had to remove the indexing ridge, as my device doesn't have a groove for it.
I was hoping this was findable, as I need to make about 50 cables. It's very likely the vendor fever dreamed up their own configuration.
