Page 2 of 2 < 1 2
#374719 - 06/08/2025 04:08 Re: Time to refurbish my MK2A. [Re: gmarsh]
time
Loc: Southwest
Well... I got:
Found empeg unit: entering program mode
Manufacturer=0089, product=88c1
starting erase [Bad result code: 0xa2
That doesn't sound good.
#374723 - Yesterday at 00:43 Re: Time to refurbish my MK2A. [Re: gmarsh]
That just sounds like it had a comms error. Still on MS-Win, eh?
#374724 - Yesterday at 03:47 Re: Time to refurbish my MK2A. [Re: gmarsh]
time
Loc: Southwest
Ok. No, this was download.c on Linux Mint.
I'll see about ordering a new null cable.
Edited by time (Yesterday at 13:37)
#374725 - Yesterday at 13:53 Re: Time to refurbish my MK2A. [Re: gmarsh]
The cable appears to be working. It could just be perhaps needing a different chipset in the USB-Serial Adapter.
What does 'lsusb' show for the adapter?
If I have a similar one here, I could re-test against it.
#374726 - Today at 04:00 Re: Time to refurbish my MK2A. [Re: time]
time
Loc: Southwest
Nope. That's not it. New null-modem cable does the same thing. It gets about 16-20% through the erase and throws that error. Any other ideas?
This is via a 9-pin to the 9-pin on the empeg.
Edited by time (Today at 04:19)
#374727 - Today at 04:07 Re: Time to refurbish my MK2A. [Re: mlord]
time
Loc: Southwest
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0040:073d
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Is that what is reported for ttyS0?
dmesg shows:
[ 0.563684] 00:03: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
Changed to stty -F /dev/ttyS0 cs8 -parenb -cstopb and tried again.
Still [Bad result code: 0xa2
Edited by time (Today at 04:17)
#374728 - Today at 19:51 Re: Time to refurbish my MK2A. [Re: gmarsh]
Tim, is it in a docking sled? If I recall correctly (Mark, correct me if I'm wrong here), the player serial port is 4800bps in the docking sled, and it won't do flash upgrades when docked.
https://riocar.org/FAQ/8/74.html#74
https://riocar.org/FAQ/7/82.html#82
#374729 - 21 minutes 57 seconds ago Re: Time to refurbish my MK2A. [Re: time]
Originally Posted By: time
dmesg shows:
Oh, okay. Not a USB-Serial cable/dongle then? A real, built-in serial port with DB-9 on the computer itself! (?)
Mmmm..
#374730 - 19 minutes 21 seconds ago Re: Time to refurbish my MK2A. [Re: gmarsh]
Here (attached) is the download binary I use, which works for me on Linux.
download.bin (0 downloads)
Page 2 of 2 < 1 2
