Page 2 of 2 < 1 2
#374719 - 06/08/2025 04:08 Re: Time to refurbish my MK2A. [Re: gmarsh]
time
Loc: Southwest
Well... I got:
Found empeg unit: entering program mode
Manufacturer=0089, product=88c1
starting erase [Bad result code: 0xa2
That doesn't sound good.
#374723 - 07/08/2025 00:43 Re: Time to refurbish my MK2A. [Re: gmarsh]
That just sounds like it had a comms error. Still on MS-Win, eh?
#374724 - 07/08/2025 03:47 Re: Time to refurbish my MK2A. [Re: gmarsh]
time
Loc: Southwest
Ok. No, this was download.c on Linux Mint.
I'll see about ordering a new null cable.
Edited by time (07/08/2025 13:37)
#374725 - 07/08/2025 13:53 Re: Time to refurbish my MK2A. [Re: gmarsh]
The cable appears to be working. It could just be perhaps needing a different chipset in the USB-Serial Adapter.
What does 'lsusb' show for the adapter?
If I have a similar one here, I could re-test against it.
#374726 - Yesterday at 04:00 Re: Time to refurbish my MK2A. [Re: time]
time
Loc: Southwest
Nope. That's not it. New null-modem cable does the same thing. It gets about 16-20% through the erase and throws that error. Any other ideas?
This is via a 9-pin to the 9-pin on the empeg.
Edited by time (Yesterday at 04:19)
#374727 - Yesterday at 04:07 Re: Time to refurbish my MK2A. [Re: mlord]
time
Loc: Southwest
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0040:073d
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Is that what is reported for ttyS0?
dmesg shows:
[ 0.563684] 00:03: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
Changed to stty -F /dev/ttyS0 cs8 -parenb -cstopb and tried again.
Still [Bad result code: 0xa2
Edited by time (Yesterday at 04:17)
#374728 - Yesterday at 19:51 Re: Time to refurbish my MK2A. [Re: gmarsh]
Tim, is it in a docking sled? If I recall correctly (Mark, correct me if I'm wrong here), the player serial port is 4800bps in the docking sled, and it won't do flash upgrades when docked.
https://riocar.org/FAQ/8/74.html#74
https://riocar.org/FAQ/7/82.html#82
#374729 - Yesterday at 20:46 Re: Time to refurbish my MK2A. [Re: time]
Originally Posted By: time
dmesg shows:
Oh, okay. Not a USB-Serial cable/dongle then? A real, built-in serial port with DB-9 on the computer itself! (?)
Mmmm..
#374730 - Yesterday at 20:48 Re: Time to refurbish my MK2A. [Re: gmarsh]
Here (attached) is the download binary I use, which works for me on Linux.
download.bin (3 downloads)
#374731 - Yesterday at 21:35 Re: Time to refurbish my MK2A. [Re: tfabris]
time
Loc: Southwest
Hey Tony! No sled. Just on the desk.
Edited by time (Yesterday at 21:36)
#374732 - Yesterday at 21:46 Re: Time to refurbish my MK2A. [Re: mlord]
time
Loc: Southwest
Sorry sir, I only act like I know what I'm doing on linux. I tried chmod 755 download.bin and trying to launch it says:
download.bin: command not found
Edited by time (Yesterday at 22:03)
#374733 - Yesterday at 22:25 Re: Time to refurbish my MK2A. [Re: gmarsh]
./download.bin
#374734 - Yesterday at 22:26 Re: Time to refurbish my MK2A. [Re: gmarsh]
Are you trying this on a simulated Linux (eg. "Linux for Windows") or some such trash, or on a native install?
#374735 - Yesterday at 22:34 Re: Time to refurbish my MK2A. [Re: time]
./download.bin
That still gets me. Frequently! I'm no expert on Linux, and my main driver is a Mac these days, and I hardly ever need to do anything at a DOS command prompt any more. Yet still, that's one of those things where, even if you know it, it still seems like it should work without the ./ in the front. Frustrating.
Someday I'll look up WHY it works that way. Still probably won't help me remember. smile
(Edit: Just did look it up. Supposedly it's a security feature to prevent a malicious program with the same name as a program in the PATH (like LS or MAN etc) from being automatically called in lieu of the real one from the operating system. Microsoft, on the other hand, chose convenience over security when designing their command line syntax.)
#374736 - Today at 00:14 Re: Time to refurbish my MK2A. [Re: mlord]
time
Loc: Southwest
Native Mint 20.2 (Uma) install on bare metal.
Ok. Now prompting for an <address in hex>
#374737 - Today at 00:30 Re: Time to refurbish my MK2A. [Re: gmarsh]
./download.bin image_file_name 10000 /dev/ttyS0
But you already attempted to use download earlier, so same syntax as before.
#374738 - Today at 02:49 Re: Time to refurbish my MK2A. [Re: gmarsh]
time
Loc: Southwest
(base) time@time-OptiPlex-790:~/Documents/mlord$ ./download.bin ../../Downloads/car2-developer-v2.01-final.upgrade 10000 /dev/ttyS0
Turn on empeg unit now
Starting erase [Bad result code: 0xa2
Yup. Increments to 24% and then errors.
I've even tried briefly shorting the 3v cell on the mainboard and retrying the reset in hopes of forcing a reset, but get the same results.
Edited by time (Today at 02:57)
#374739 - 32 minutes 35 seconds ago Re: Time to refurbish my MK2A. [Re: tfabris]
(...Microsoft, on the other hand, chose convenience over security when designing their command line syntax.)
DOS didn't have directories until 2.x, so commands were always in the current directory (or built-in), so it didn't have a PATH environment variable. Microsoft chose (as they almost always do) backwards compatibility.
Page 2 of 2 < 1 2
