#37712 - 30/08/2001 16:54 Emplode Freeze
Elite M3
Loc: Sunnyvale, CA, USA
I use version 1.02 or 1.03, I can't remember, but I find that the emplode software will freeze upon Synch if I take too long to move files over, make changes OR try to move too many files/make too many changes. Is this a known thing? It is really frustrating when i am thinking about where to put things and move some songs around, make tons of changes, and then when I synch, I get the initializing player screen. I have let the player initialize all night and still no dice, so I know it is frozen. I see in Win2k task manager that the program isn't responding either. Any fix for this?
#37713 - 30/08/2001 17:02 Re: Emplode Freeze [Re: Elite M3]
As far as we knew, Emplode has been pretty stable in the most recent incarnations. So if you can reproduce a bug, it's worth getting details on it for reporting.
First: Make sure you're running the latest version (1.03 as of this writing) of both Emplode and the player software.
Next, before you sit down to do a big operation on Emplode, activate the logging feature.
Finally, if Emplode crashes, zip up that log file and send it to support.
#37714 - 31/08/2001 08:54 Re: Emplode Freeze [Re: tfabris]
Elite M3
sounds good. I will do just that!
Thanks!
#37715 - 11/09/2001 14:07 Re: Emplode Freeze [Re: tfabris]
Elite M3
I have done everything stated. I upgraded to the very latest versions of everything and loaded the developer image. I got the log files and after letting the Empeg sit for about 10 minutes (connected to the computer and emplode open) and remembered I wanted to turn on the HD indicator. I did that, then hit synch, and the emplode froze. I looked at the log, and it states that there is no player connected to the system...along with other stuff I don't really understand. But the main error is somehting to the effect of: "hmmm...seems as though the player is not connected" shutting down.
I will send the log files if requested. Let me know.
Thank you,
Jason
#37716 - 11/09/2001 14:08 Re: Emplode Freeze [Re: tfabris]
Elite M3
Any word on when version 2.0 is coming out? Everyone on the BBS seems to think that this will fix other problems i am having as well (caching songs and skipping without delay). I can't find any info anyplace about it.
#37717 - 12/09/2001 05:41 Re: Emplode Freeze [Re: Elite M3]
Have you actually contacted the empeg support team directly about this ?
__
#37718 - 06/01/2002 21:14 Re: Emplode Freeze [Re: Elite M3]
jdandrea
Loc: New Jersey
FWIW, this appears to have just happened w/my 2.0b7 install. I'm synching about 2GB worth of MP3s (off a Jaz drive). I've done this multiple times already with 2.0b7 without incident so I'm not sure what's up. I didn't realize there was a logging feature - whoops. I'm not sure if I should reboot the player or not at this point (but then is there any choice) ... there probably isn't any way to revert so I will most likely remove the items I added and start over.
-- JD - SN# 040104008 (120GB Blue, Digital Out)
#37719 - 06/01/2002 21:17 Re: Emplode Freeze [Re: jdandrea]
jdandrea
Loc: New Jersey
Auuuugh! Mistake, I suppose. I rebooted, it came up fine, but when I went to connect via emplode, the display is now showing "synchronising" again only I'm not synchronising.
#37720 - 06/01/2002 21:34 Re: Emplode Freeze [Re: jdandrea]
jdandrea
Loc: New Jersey
Ugh. This can't be good (see bolded lines).
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg50-hijack ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Sun Jan 6 19:37:40 EST 2002
empeg-car player (hardware revision 9, serial number 30103046)
Command line: mem=16m
Memory: 15000k/16M available (976k code, 20k reserved, 384k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004d80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
hdb: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:e6
Partition check:
hda:waiting for connections
hda1 < hda5 hda6 > hda2 hda3 hda4
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init
empeg init 0.8
Mounting proc
Starting player
player.cpp : 550:empeg-car 2.00-beta7 (internal) 2001/12/22.
! tags.cpp : 61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1335 Dec 22 2001
Vcb: 0x408cd000
! mp3_decoder.cpp :1052:Failed to seek to offset 1118557, error=0xc0044000
#37721 - 07/01/2002 03:10 Re: Emplode Freeze [Re: jdandrea]
Nope. All of these messages appear harmless. The reiserfs warning is fine -- it's not reiserfs, so it won't mount.
The 0xC....2 error is ENOENT -- you don't have a tags file. It should be rebuilt when the player starts.
The failed to seek to offset is also fairly common...
#37722 - 07/01/2002 03:11 Re: Emplode Freeze [Re: jdandrea]
This is to be expected. The database wasn't rebuilt at the end of the last sync. Emplode has to trigger a rebuild before it can download it. This results in the "synchronising" screen appearing.
#37723 - 07/01/2002 23:32 Re: Emplode Freeze [Re: Roger]
jdandrea
Loc: New Jersey
Got it. Makes sense now. I wound up needing to fsck the drives (with the swap on and all that). After that, worked like a charm.
