#39416 - 25/09/2001 09:49 How good is Empeg Taxi?
Dearing
Loc: Florida
In light of recent events, I've just ordered a Mk2a (I'll never call it RioCar anymore...). Anyway, I've got about 8 gigs of music on my Mk1(split over 2 drives), and most of it isn't backed up (at least not in the same place), so I'd like to copy all the FIDs from the Mk1 to the Mk2. I have no problem swapping in one drive at a time and manually copying the FID directories, but my question is whether this is my only option. I know it wouldn't REALLY void the warranty on the rest of the unit to temporarily put in a second drive, but have upgraders in the past found a better way to keep the same music without opening the case the first day out of the box?
Can I use EmpegTaxi to pull back the entire FID directories with wildcards from the Mk1, or do I have to set up a script to do it? Is there a transfer size limitation in EmpegTaxi?
Thanks,
Jason
_~= Dearing =~_
_~= Dearing =~_
#39417 - 25/09/2001 10:01 Re: How good is Empeg Taxi? [Re: Dearing]
There's a util that comes with emplode called "empegclone". This only works from a lower serial number to a higher one, and only with both players on USB.
It's slow, but it will clone your old player to your new one. It was written just for this scenario.
#39418 - 25/09/2001 10:12 Re: How good is Empeg Taxi? [Re: altman]
This only works from a lower serial number to a higher one...
Greetings!
I also thought this was only from a Mark I to a Mark 2. Is this true, or can you go from a Mark 2 to a Mark 2?
Paul G.
SN# 090000587 (96GB Smoke)
#39419 - 25/09/2001 10:32 Re: How good is Empeg Taxi? [Re: altman]
Dearing
Loc: Florida
Fantastic! I guess I never paid much attention to the original discussions of EmpegClone. Does it handle multiple drives -> single drive well?
_~= Dearing =~_
_~= Dearing =~_
#39420 - 25/09/2001 11:26 Re: How good is Empeg Taxi? [Re: Dearing]
Yes, it has no concept of drives, just FIDs - like emplode.
#39421 - 25/09/2001 11:27 Re: How good is Empeg Taxi? [Re: pgrzelak]
You can go from mk2 to mk2, but beware that the datecode at the front of mk2 serial numbers is the wrong way round (month/year, not year/month) which may restrict your success.... it's a numeric comparison operation in empegclone.
I've cloned a 20GB player with v1.03's empegclone with no problems - it wasn't fast though.
#39422 - 25/09/2001 11:46 Re: How good is Empeg Taxi? [Re: altman]
loren
side note... the serial number thing...
could you clarify?
if my serial is 080000446:
08 is month
00 is year
00446 is the unit number in order of production?
is that how it breaks down?
|| loren.cox ||
|| loren ||
#39423 - 25/09/2001 15:46 Re: How good is Empeg Taxi? [Re: Dearing]
Jazzwire
Loc: Guernsey
empegTaxi isn't currently a good choice for multiple file downloads.
Maybe in a later version... =)
Jazz
(List 112, Mk2 12 gig #40. Mk1 4 gig #30. Mk3 1.6 16v)
Jazz
(List 112, Mk2 42 gig #40. Mk1 4 gig #30. Mk3 1.6 16v)
#39424 - 25/09/2001 17:18 Re: How good is Empeg Taxi? [Re: loren]
Yup, that's it. Serial numbers are ascending, but re-started with 1 for the mk2s. mk2a's follow on directly from the mk2's, but are xx01's as they were all made in 2001 I think (don't remember seeing a 1200 for example).
