#40285 - 04/10/2001 18:25 Rubber piece inside knob
robricc
While changing the color of my screen, i discovered a black rubber piece inside the knob. I don't remeber seeing it before.
It looks like it's supposed to be a circle (like a rubber band) but mine was cut. Also, it looks like it was dislodged from wherever it's supposed to be. My knob is back on now, but I am sure that the rubber piece is installed improperly.
Can someone please tell me where this is supposed to go, and how it's supposed to go in there.
Thanks,
-Rob R
12GB MK2 Blue 090000736 (6166 in the queue)
10GB "Backup" MK2a Blue 030102953
#40286 - 04/10/2001 18:35 Re: Rubber piece inside knob [Re: robricc]
I got a rubber washer with my replacement knob, but I didn't end up using it. The replacement knob grips the shaft just fine without it.
Try it without the washer and see if it's OK for you.
#40287 - 04/10/2001 18:38 Re: Rubber piece inside knob [Re: tfabris]
muzza
is your rotary controller a smooth or does it have the flat spot?
I think that if you have the flat spot you shouldn't need the O ring.
Nice apostrophe work Tony
Murray
Go-Wit-Da-Fro
#40288 - 04/10/2001 18:41 Re: Rubber piece inside knob [Re: muzza]
Thank you. Note that it's used correctly in that particular instance.
(Apostrophe== contraction for "it is" or "it has", no aphostrophe== posessive form of the pronoun.)
#40289 - 04/10/2001 18:51 Re: Rubber piece inside knob [Re: tfabris]
robricc
I sent my empeg for repair a few months ago. Since then, I havn't taken the knob off until now. It may be possible the knob was swapped then.
If I put the knob on without the washer, it is too loose to use.
-Rob R
#40290 - 04/10/2001 19:00 Re: Rubber piece inside knob [Re: robricc]
muzza
two small drops of epoxy on the shaft, each side of the knob spines (let it dry first) stop the know slipping forever! Mwa ha ha
Sorry punctuation police, no need for contractions in this post. You might say that I have already filled my conntractual obligations.
or not
Murray
Go-Wit-Da-Fro
#40291 - 04/10/2001 20:10 Re: Rubber piece inside knob [Re: robricc]
borislav
Loc: Sunnyvale, CA, USA
See a previous post by Rob.
Borislav
#40292 - 05/10/2001 02:41 Re: Rubber piece inside knob [Re: robricc]
David
Loc: Cambridge
I replace all rotary knobs with the new type as standard procedure. If you have diffficulty using the broken rubber ring, email [email protected] and I'll get a new on sent out to you.
David
// I'm probably not speaking on behalf of empeg/SONICblue here...
#40293 - 05/10/2001 07:41 Re: Rubber piece inside knob [Re: tfabris]
beaker
Loc: England
I left the 'O' ring out too for a while, then my knob got a bit slippy so I had to put it back in for that nice tight & rigid feeling.
Marcus (beaker)
32 gig (various colours)
