#40667 - 07/10/2001 05:06 OT - Wanted, MPx to WAV conversion software
debauch
Loc: West Midlands, England
Hi,
For various reasons, I need a nice and simple piece of software which will do conversion from MPx (2 or 3) to WAV (PCM, 44.1KHz, 16 bit). I don't need anything fancy - ideally it should be drag and drop (if Windows) or command line (Lin/Win) and default to putting new files in the same directory as the existing ones with the same filename (but different extension, obviously).
All that I've found have been designed to do much more than I actually need them to and, as a consequence, are too fiddly.
Any ideas?
Cheers and apologies for posting this here - it's the only place I know which may have the right answers!!
Nicholas.
18GB red s/n 080000299, original pos'n 8724. Reproduction of this post is not permitted.
-- 18GB red s/n 080000299
#40668 - 07/10/2001 06:50 Re: OT - Wanted, MPx to WAV conversion software [Re: debauch]
TommyE
Loc: NORWAY
Earlier versions of Winamp could do this.
Select the discwriter plugin, and the WAV files will come to you.
I used this before any cd writer programs would let you burn music cd's on the fly.
Haven't used this feature of Winamp for a while but I think it should still work.
TommyE
#40669 - 07/10/2001 07:35 Re: OT - Wanted, MPx to WAV conversion software [Re: debauch]
easy cd-da comes with a file converter program. it has a big window that says "drag files here" and a convert button. just drag the files into the window and hit convert
32Gig MK2 In 2001 VW Golf TDI
#40670 - 08/10/2001 06:00 Re: OT - Wanted, MPx to WAV conversion software [Re: debauch]
tms13
Loc: Lochcarron and Edinburgh
mpg321:
 outfile mpg321 -w outfile (file|URL|-)
should do. You could even make a short shell-script:
#!/bin/bash
#untested!
mpg321 -w `basename $1`.wav $1
Toby Speight - 040103385
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#40671 - 09/10/2001 08:04 Re: OT - Wanted, MPx to WAV conversion software [Re: debauch]
I use "lame --decode". It's only a command-line tool, but it works quite well.
