#41457 - 12/10/2001 08:13 IP Interface going down
mardibloke
Loc: Penarth, UK
Have been using Empeg Mk2 with IP at home for a while, no problems. Hooked it up to an Ethernet hub at work, and initially IP is ok, but after a while the IP interface stops working ( I think I may have noticed player reboot ). Don't have serial cable here to see whats going on. Hub is 10/100 switchable, have displayserver 2.0 install, and dev 1.03. Any comments ?
Rod ,UK Mk2a Sn:1911 Mk2 64gig S/No:341
Rod, UK
#41458 - 12/10/2001 12:32 Re: IP Interface going down [Re: mardibloke]
fvgestel
Loc: Netherlands
Have you tested if you can ping it?
I can imagine that at work, a lot more people connect to the empeg at the same time; this can consume a lot of memory, causing the player to shutdown displayserver.
If you want to reserve more memory for displayserver, you can add the following line to /empeg/var/config.ini
[startup]
reservecache=12
Frank van Gestel
Frank van Gestel
#41459 - 15/10/2001 17:01 Re: IP Interface going down [Re: fvgestel]
mardibloke
Loc: Penarth, UK
Even not running Displayserver, when you try and PING, initially it works, but after a while there is no response to PING.
Rod, UK
#41460 - 15/10/2001 17:44 Re: IP Interface going down [Re: mardibloke]
Ezekiel
Loc: NH USA
I know this is stupid (I did it) but check for IP address conflicts, especially if you network has some fixed IP addresses (usually printers - or empegs). Conversely, don't use a fixed address that's within a DHCP's scope for the same reason. I drove myself nuts with this, it'd work for a while then quit, not ping etc...
Also, when you switch to DHCP from the config screen of emplode, be sure to cycle the power to have the change take effect.
-Zeke
WWFSMD?
#41461 - 17/10/2001 18:11 Re: IP Interface going down [Re: Ezekiel]
mardibloke
Loc: Penarth, UK
Thanks for the suggestions, its my own subnet at work, and I did try a couple of fixed address' that were free ( ping'ed etc to check not in use too ). Odd that I could get a connection with Emplode and start to sync but then would loose contact ( after about 20mb transfered ).
Guess I need to remember to take my serial cable in and see whats going on.
Rod, UK
