#41522 - 13/10/2001 12:01 Synchronisation Error Stage 6
Chuck
I am receiving a synchronisation error at stage 6 every time I use Emplode. Emplode stops with error message, but the player continues and completes the synchronisation. If I exit Emplode, wait for the player to finish and then run Emplode again, all the changes are in the database and on the player. Has anyone else experienced this or have any idea what is causing the error?
#41523 - 13/10/2001 12:06 Re: Synchronisation Error Stage 6 [Re: Chuck]
Giving the exact error number might be helpful. There is a table of synch errors available from the FAQ section of this BBS...
#41524 - 13/10/2001 12:39 Re: Synchronisation Error Stage 6 [Re: tfabris]
Chuck
The error is:
The synchronisation process failed during stage 6:
Operation not permitted error 0xffffffff
I've looked at Roger's Diagnosing Synchronisation Errors page, but I don't quite understand what "Tap in the last two digits of the number you first thought of" refers to.
#41525 - 14/10/2001 04:05 Re: Synchronisation Error Stage 6 [Re: Chuck]
Well, you get 0xffffffffXX, the two X'es being the two numbers you need to use. (I think). That's what I did with the error I got anyway.
Riocar 58gig (48gig + 10gig IBM travelstar) S/N : 10101747 red
