#41907 - 17/10/2001 13:15 Press & Hold Volume button doesn't do anything
phaigh
Hi all,
It used to change from info->visual and vica versa, but I can't get it to do anything in 2.0 Beta3.
Didn't see anything about this in the release notes, so guessed it was a bug.
Paul.
Paul Haigh, Reg. 4120
(mk1) 6GB, Blue, 00254
(mk2) 12GB, Red, 00357
Paul Haigh, Reg. 4120 (mk1) 6GB, Blue, 00254 (mk2) 12GB, Red, 00357
#41908 - 17/10/2001 14:49 Re: Press & Hold Volume button doesn't do anything [Re: phaigh]
The empeg team is currently deciding what to do with that. There are a few different ideas they've been kicking around. The next release will probably have something useful for it to do.
#41909 - 17/10/2001 14:51 Re: Press & Hold Volume button doesn't do anything [Re: tfabris]
phaigh
That's a real pity, I really liked the previous functionality, especially with the 'default to full screen info' behaviour.
Paul.
#41910 - 17/10/2001 14:59 Re: Press & Hold Volume button doesn't do anything [Re: phaigh]
You can still do that. Before, it simply duplicated the "down" button behavior. The down button still works as it always had.
#41911 - 17/10/2001 15:03 Re: Press & Hold Volume button doesn't do anything [Re: tfabris]
phaigh
Aaah, didn't know that - I've always used the volumn knob....
Groovy!
Paul.
#41912 - 20/10/2001 19:15 Re: Press & Hold Volume button doesn't do anything [Re: tfabris]
It works really well now as the entry into the BreakOut game!
#41913 - 23/10/2001 15:36 Re: Press & Hold Volume button doesn't do anything [Re: mlord]
srhodes
Loc: Derbyshire, UK
I thought it used to always get you straight to the Info: Off setting from your current Info: setting and then back to Info: Track. Now it just toggles between your current setting and Info: Off even if your current setting is already Info: Off meaning it doesn't actually do anything.
___________________________
Steve - 18GB Mk II Sssmokey
Steve
2x80GB Mk II with Illuminated buttons
