#42329 - 18/10/2001 06:06 Current bug list
I'll post this from time to time. I've included only the bug summary, but most of them are self explanatory. It would be best if individual bugs were still discussed in individual threads, instead of replying to this post.
When submitting information about an existing bug, please be sure to quote the bug number.
Emplode: Free space doesn't increase when deleting tracks in emplode (#1054)
Emplode: Cut & paste into track properties doesn't forget font (#1056)
Emplode: Advanced Sorting and Listing (#1060)
Emplode: Emplode truncates exit event WAV (#1031)
Emplode: Network configuration dialog should allow DNS server entry in emplode (#1080)
Emplode: User should be warned that deleting a playlist doesn't do what they're expecting (#1105)
Emplode: Browser launched from emplode does not come to front (#330)
Emplode: Tracks dropped on web view aren't deduplicated (#936)
Emplode: Error writing player configuration (#919)
Emplode: Missing description on Windows installer (#1116)
Emptool: emptool stops talking to unit during restart stage (#989)
Player: Rapidly plugging unplugging USB while empeg is booting causes blue-screen in USB driver (#541)
Player: There's no custom shuffle tag for skip_count (#474)
Player: Now and Next screen shows multiple repeats of single track (#1052)
Player: Time mode info popups - cosmetic bug (#1073)
Player: Play count (& other stats?) not updated in Repeat track mode (#1104)
Player: No close icon on sync dialog and cancel is greyed out (#79)
Player: Rewind time pop-up window moves slowly. (#17)
Player: Set the clock from RDS on Mark 1 (#188)
Player: InfoTex visuals contain blitter and don't always get proper info fed to them (#976)
Player: "Title bar" text on search screens overlaps "xxxx tunes" text (#1020)
Player: Stop car player barfing down the serial port on exit (#778)
Player: No "pause" or "mute" indicator on Info:Tuner screen (#1109)
Player: Now and Next overridden at in-car startup. (#1111)
Player: Anna Vu freaks out when tuner is pause/muted (#1112)
Player: Info screen clock stays at 24hr when Clock visual is at 12hr (#1114)
Player: Garbled screen on Mk1 after upgrade (#1117)
Player: Flashes to a screen with one horizontal line across the middle of the screen and reboots (#1119)
Player: Scrambled setting when upgrading from 1.03 to 1.10 (#927)
Player: Changing volume from the remote control is too slow (#1121)
Player: Radio is silent when booting into radio mode. (#1005)
Tuner: Too much bass in tuner mode (#1055)
Tuner: Bottom-button-hold only switches Off<>Radio in Tuner mode (#1113)
Upgrade: Can't minimise empegUpgrade (#403)
Upgrade: Upgrade icon and Name (#75)
Upgrade: Upgrade does not listen for player "peace..." message soon enough (#1058)
Upgrade: Can't upgrade player on COM3 with 2.0b3 upgrader (#1115)
#42330 - 18/10/2001 06:28 Re: Current bug list [Re: rob]
"Tuner: Bottom-button-hold only switches Off<>Radio in Tuner mode (#1113) "
I have this with the player too, but only when at home. IN Car it's fine.
MK II BLUE/RED 12GB #923 + RADIO
#42331 - 18/10/2001 06:52 Re: Current bug list [Re: rob]
jane
Loc: Copenhagen SW, Denmark
> Occassional errors writing player configuration. (#919)
This happens *every time* for me.
Marius /Wscort Cab + Mark II)
#42332 - 18/10/2001 06:54 Re: Current bug list [Re: jane]
We think Richard has found what was causing this: if so, FITNR.
#42333 - 18/10/2001 07:23 Re: Current bug list [Re: rob]
grgcombs
Loc: Dallas, TX
Also in the player, having [output] notify=1 in config.ini causes the machine to constantly reboot after kernel install. Here is the link
g
RioCar (40Gig) Blue/Red/Green
'01 Audi A4 2.8 Quattro
#42334 - 18/10/2001 07:31 Re: Current bug list [Re: grgcombs]
grgcombs
Loc: Dallas, TX
Sorry, you've already got that one in there as #1119, I just missed it. I guess it helps that we found the a source of the problem though. Someone mentioned just now that you guys might be dropping notify support anyway, I wonder if that's why it's freaking out?
#42335 - 18/10/2001 14:35 Re: Current bug list [Re: rob]
Terminator
Loc: Dallas, TX
Maybe it would be a good idea to post this in the announcements forum so it doesnt get buried. Ive never seen so many posts in the bug forum in so short an amount of time. This is chaos.
Sean
#42336 - 18/10/2001 15:12 Re: Current bug list [Re: Terminator]
grgcombs
Loc: Dallas, TX
I have to disagree ... altavista says the following items are chaos....
Quebec
Tatoo
shield
horse
g
