#42715 - 19/10/2001 14:33
Transient at the 'end' of a song too.
Hi all,
It'd be really nice, in the sprit of 'top of the pops' (or MTV, if you prefer) to have the transient info line appear at the end of the song as well as the beginning.
Perhaps 5-10 seconds from the end?
Just seems a nice touch.
Paul.
Paul Haigh, Reg. 4120
(mk1) 6GB, Blue, 00254
(mk2) 12GB, Red, 00357
#42716 - 19/10/2001 16:03
Re: Transient at the 'end' of a song too.
[Re: phaigh]
Agreed.
How about start; five minute intervals; and 10 seconds from the end?
Murray
new styleee
Murray
Is it the 'N', or the 'Zero'?
#42717 - 19/10/2001 18:42
[Re: muzza]
Particularly if you doubled the scrolling speed, but kept the scrolling duration the same, so you would have two chances to read the information before it disappeared.
#42718 - 20/10/2001 04:51
[Re: phaigh]
Related to this, I would like to have a remote button trigger the transient info display without side effects. Currently 'Select Mode' button triggers the display, but also reseeds the visual. I would like the two functions separated (one possibility is to use press and press-and-hold on that button).
Dragi "Bonzi" Raos
Zagreb, Croatia
Dragi "Bonzi" Raos
Q#5196
MkII #080000376, 18GB green
MkIIa #040103247, 60GB blue
#42719 - 20/10/2001 06:45
[Re: bonzi]
Loc: Druten, The Netherlands
Did you try press-and-hold visual button?
Update: (still learning to check before talk) unfortunately it only shows which info mode it is in and doesn't show the actual info
ญญ______________
Edwin de Vaan
[white]ญญ______________[/white] Edwin de Vaan aka FLaSHmAStER
#42720 - 20/10/2001 07:21
[Re: edwin]
I think hold-visual is used/reserved for access to all visuals when the user has favourite visuals defined.
Dragi "Bonzi" Raos
Zagreb, Croatia
Dragi "Bonzi" Raos
Q#5196
#42721 - 20/10/2001 07:37
[Re: bonzi]
Hold the bottom button on the front panel. That'll make transient pop up. You have to do it twice, though.
My preference would be to have the bottom button on the front panel toggle between "Transient" and "Track" instead of its current toggle between "Transient" and "Off". Then I could look up track details in the middle of a song very easily while leaving it on transient. ___________
#42722 - 22/10/2001 15:22
Easiest way I've found is to just double-click the top button on the front panel or the stun/kill button (aka "hush" or "pause") on the remote. You get a tiny glitch in the playback, but it's not more than about 1/10 second or so.
#42723 - 22/10/2001 17:09
I second that. I've been doing this a ton lately. It would be nice to just switch to track info with one button hold from transient.
|| loren.cox ||
#42724 - 22/10/2001 17:24
Greetings!
Actually, the stun / kill button is the Visual button on the new remote... I am tempted to hold down the Visual button, but I am worried about doing so in highly populated areas.
Paul G.
SN# 090000587 (96GB Smoke)
SN# 030103046 (10GB Blue - Emergency Spare)
#42725 - 23/10/2001 05:30
[Re: loren]
Press-and-hold info button: this brings up the Track Details popup with all information from Track screen and more. Another hold brings you back. I think it is decent substitute for Tony's and your wish.
Dragi "Bonzi" Raos
Zagreb, Croatia
Dragi "Bonzi" Raos
Q#5196
