#43033 - 20/10/2001 16:16 what file stores the remote control information
silvercas
i have 2 remotes in my car and it is annoying. so I want to capture the code from my pioneer remote ( using my philips pronto) and input this code into the empeg to be used to mark files for deletion. how would I got about doing this?
#43034 - 20/10/2001 17:16 Re: what file stores the remote control information [Re: silvercas]
I'm not sure exactly what you want to do, but the IR commands are handled first in the kernel, in arch/arm/special/empeg_input.c .. in there, you can translate them to mean anything you want, before they are passed to userland (the player).
#43035 - 20/10/2001 17:29 Re: what file stores the remote control information [Re: silvercas]
What you need is a specially-modified kernel by Frank Van Gestel called "IR_TRANS". Do a search on the BBS for information on how to use it to both capture the codes as well as use these codes on the empeg.
#43036 - 20/10/2001 23:53 Re: what file stores the remote control information [Re: tfabris]
silvercas
on http://fvgestel.dyndns.org/empeg/ I found the ir hack only goes to kernel 1.03 . I just installed 2.0 so basically Im up a creek right?
#43037 - 21/10/2001 09:09 Re: what file stores the remote control information [Re: silvercas]
silvercas
help
#43038 - 21/10/2001 09:17 Re: what file stores the remote control information [Re: silvercas]
you can just reinstall 1.03 until that hack get updated
32Gig MK2 In 2001 VW Golf TDI
