#45027 - 04/11/2001 13:59 offset?
jwickis
Loc: India
What does 'offset' mean anyway I noticed about half of my collection is '0' the rest rather large numbers?
Edited by jwickis (04/11/2001 14:19)
#45028 - 04/11/2001 15:41 Re: offset? [Re: jwickis]
bonzi
Offset is beginning of actual MP3 stream (I don't know units - bytes?). Those with large offsets probably have ID3v2 tags prepended to them. See r3mix.net for a rant against ID3v2 tags, and Mark's utility for extracting and removing them.
#45029 - 04/11/2001 16:06 Re: offset? [Re: bonzi]
jwickis
Loc: India
Is there a utility your aware of that runs on Win 98?
#45030 - 04/11/2001 16:14 Re: offset? [Re: jwickis]
bonzi
Many. I use MP3 Tag Studio (mostly to set both ID3v1 and ID3v2 tags in controlled manner, but it can also remove them.)
#45031 - 04/11/2001 16:33 Re: offset? [Re: bonzi]
jwickis
Loc: India
I have been using MPTagger, I had used MP3 Tag Studio v1.61 until I changed every single one of my 800 files to the same thing accidently, big mess. I'll see what the new version has to offer.
#45032 - 04/11/2001 16:42 Re: offset? [Re: jwickis]
bonzi
... and didn't notice untill it was too late for undo, eh? Undo did save my hide once or twice
#45033 - 04/11/2001 16:52 Re: offset? [Re: bonzi]
jwickis
Loc: India
Uh yes. You have to really goofproof things for me at times, even 'undo' needs a 'undo'.
Edited by jwickis (04/11/2001 16:53)
#45034 - 04/11/2001 16:58 Re: offset? [Re: bonzi]
jwickis
Loc: India
OK does the 'offset' really matter much in the bigger scheme of things?
#45035 - 04/11/2001 17:05 Re: offset? [Re: jwickis]
bonzi
No, not really. I suppose empeg 'writes it down' in order to skip over tags (as opposed to waste time and cache by reading them), so the difference is a single seek call. Also, unless ID3v2 tags contain something as extravagant as hi-res scan of CD booklet, they still use only several kilobytes. As I said in another thread, I still think it is a good idea to keep ID3v2 tags, provided one tidies them up for one's own use.
#45036 - 04/11/2001 17:10 Re: offset? [Re: bonzi]
jwickis
Loc: India
I have been using Winamp to copy the v1 info to v2 but I have a long way to go to do all my files, a long way.
#45037 - 05/11/2001 06:09 Re: offset? [Re: jwickis]
Wow! You've got a lot of patience! I simply use Tag & Rename, a VERY good utility. Great at doing 'batch tagging'
Give it a go, I'm pretty sure you'll like it. (I liked it better than mp3tagstudio because in the days I started using it, mp3tagstudio didn't do v2 tags yet)
Theres a fully-functioning one-month trial version downloadable from the site.
