#45627 - 08/11/2001 19:00 Voltage outputs at home??
dewdman42
Anyone know what voltage the RCA outputs are on the MkII? I tried to hook my Empeg up to a home stereo that has 2.5v inputs and had major distortion going on... When I turned the Empeg way down...I could limit the distortion but had no volume. I'm pretty sure its a voltage mismatch. Anyone know?
#45628 - 08/11/2001 19:14 Re: Voltage outputs at home?? [Re: dewdman42]
car-sled outputs are 4v, home outputs are 1v.
You sure you didn't plug it into the PHONO input?
#45629 - 08/11/2001 19:21 Re: Voltage outputs at home?? [Re: tfabris]
dewdman42
Positive. Its a Meridian system. It doesn't have phono inputs. B-) It has digital and analog inputs that are adjustable from a range of 1 to 2.5 volts. However, at 2.5 volts, the problem should not have been distortion I wouldn't think..
#45630 - 08/11/2001 20:02 Re: Voltage outputs at home?? [Re: dewdman42]
Was the distortion present on all songs or just on one song?
If you were running 2.0b3, perhaps you were encountering the known bug where some songs get overdriven.
Also remember that the home loudness and EQ settings are different from the car. If you crank the loudness or boost the EQ, it might clip. Check that.
