#45752 - 09/11/2001 02:41 Voltmeter?
jane
Loc: Copenhagen SW, Denmark
I seem to remember that on one of the wires into the empeg
player, the actual voltage can be found? Would it be possible
to integrate a Voltmeter in a ststus page? :-)
(Or, could you provide information that would enable us to write such an application?
Marius (Escort Cab + Mark II)
#45753 - 09/11/2001 06:23 Re: Voltmeter? [Re: jane]
No, it doesn't have a voltmeter - just a voltage threshold for state save.
Damn, I *knew* there was something else I meant to put in the tuner module... I should have been using one of the other analogue inputs as a car voltage monitor.
#45754 - 09/11/2001 06:31 Re: Voltmeter? [Re: altman]
jane
Is this hackable with a voltmeter? :-)
My guess would be to solder together two of the legs of a chip... or would firmware have to be changed.... hm...
Which wire is sensed for the "low power icon"?)
Could people without a sony-wired-remote use this input with some inguenity.. hm...
*thinking hard*
#45755 - 09/11/2001 06:38 Re: Voltmeter? [Re: jane]
Firmware would need changing, and it's a OTP PIC. Sorry!
The main power feed (minus a diode drop in the input protection circuitry) is used to generate the low power interrupt.
#45756 - 09/11/2001 06:47 Re: Voltmeter? [Re: altman]
jane
Hm.. Modulating the main power supply would require some heavy equipment and... ;-)
(I think I'll pass on that project)
Marius (Escort Cab+ Mark II)
#45757 - 09/11/2001 07:05 Re: Voltmeter? [Re: altman]
jane
What about the Microphone-in?
#45758 - 09/11/2001 10:23 Re: Voltmeter? [Re: jane]
It's ac-coupled, no good for sampling voltages - apart from the range mismatch, obviously.
#318375 - 22/01/2009 07:13 Re: Voltmeter? [Re: altman]
thenominous
I wonder if it would be possible with the pcats tuner kits ?
#329452 - 28/01/2010 22:50 Re: Voltmeter? [Re: thenominous]
siberia37
Loc: Tacoma,WA
You could do this with an Arduino with an Ethernet shield for not too much money.
#329494 - 29/01/2010 15:24 Re: Voltmeter? [Re: siberia37]
You don't even need the Ethernet shield -- the Arduino boards can do serial just fine.
#329505 - 29/01/2010 17:40 Re: Voltmeter? [Re: canuckInOR]
siberia37
Loc: Tacoma,WA
Forgot about that duh. But then that leaves your serial port unavailable for any other fun toys, and I remember the Empeg's dock serial port being a real pain to get the TX/RX combination right.
