#47007 - 17/11/2001 10:19 Config.ini
94cobra
My player has somehow lost the data in the config.ini file. It just pulls up this in Emplode:
Could someone post the text that is supposed to be here so I can resync it to the player.
Sonic Blue 03 Cobra Vert Owner!!!
#47008 - 17/11/2001 11:19 Re: Config.ini [Re: 94cobra]
crazymelki
Loc: Switzerland
Did you install Displayserver 2.0b2?
crazymelki.com
#47009 - 17/11/2001 12:35 Re: Config.ini [Re: crazymelki]
94cobra
I have had DisplayServer installed prior to v2. But have not messed with the unit with anything except Emplode and installing v62 Hijack. The data was there yesterday. I had just added new remote codes. Today gone.
P.S. I would like for Displayserver to work again.
#47010 - 17/11/2001 17:13 Re: Config.ini [Re: 94cobra]
Just delete everything, sync, then use the "File->ConfigurePlayer" menu to set up the basic information again [untried, but probably what needs doing].
I have also noticed Emplode sometimes adding garbage to the end of config.ini, especially whenever there are lines that are not in "standard syntax" (something=value).
Edited by mlord (17/11/2001 17:30)
#47011 - 17/11/2001 17:26 Re: Config.ini [Re: mlord]
94cobra
That worked. I had reinstalled beta2, but that didn't fix it. Deleted the garbage and synced. When it came back it was there.
Thanks for the suggestion.
