#47730 - 24/11/2001 15:18 Fujitsu 30GB & IBM 10GB.. Will it work?
Fastrack
Loc: Toronto, Ontario Canada
Computer Geeks has a Fujitsu 30GB drive for quite a good deal.
http://www.compgeeks.com/additem.asp?invtid=MHL2300AT
Just wondering if anyone thinks I'll have any problems using this drive with the 10GB IBM that my RioCar came with?
djc any luck with the 30GB you ordered?
Ben Rio Car 10GB + 60GB Toshiba ([green]Green[/green]) - Serial # 30102833
#47731 - 24/11/2001 16:26 Re: Fujitsu 30GB & IBM 10GB.. Will it work? [Re: Fastrack]
djc
Loc: chicago
the drive arrived yesterday, but i haven't had a chance to install it yet. i'm hoping to take a crack at it tomorrow, and i'll post the results here.
--dan.
#47732 - 26/11/2001 08:33 Re: Fujitsu 30GB & IBM 10GB.. Will it work? [Re: djc]
djc
Loc: chicago
everything went well with my install. the new drive seems fast and quiet, and i had no problems fitting it in my mk2a (thank you fujitsu for including the jumper block!). after stress testing for a couple of hours, i set up about 35GB of music to sync overnight, and everything looks great this morning.
--dan.
#47733 - 26/11/2001 08:48 Re: Fujitsu 30GB & IBM 10GB.. Will it work? [Re: djc]
Fastrack
Cool, I think I'll order one! Hopefully it works well with the IBM drive as the master :)
#47734 - 26/11/2001 10:37 Re: Fujitsu 30GB & IBM 10GB.. Will it work? [Re: djc]
Congrats. So I take it the FAQ had all the necessary information you needed?
#47735 - 26/11/2001 11:16 Re: Fujitsu 30GB & IBM 10GB.. Will it work? [Re: tfabris]
djc
Loc: chicago
the FAQ was excellent.
i actually upgraded two units; on the first, i added a 30GB drive to the existing 10GB fujitsu. with the second, i replaced the 10GB drive with two new 30GB drives. i decided to venture into unknown territory by installing both new drives simultaneously, and see how the builder would handle it. in fact, it formats up both drives without a hitch. however, if the serial port output is to be believed, it only stress tests the first drive in the pair. i let it run a couple of hours, and it never seemed to touch the second drive at all.
nonetheless, i have loaded some music on that unit as well, and (other than known issues with timeouts under 2.0b3), it seems fine.
after playing with the 60GB unit for a couple of hours, my remote is no longer responding, even after reboots. i suppose that's another topic for another thread, though...
--dan.
#47736 - 26/11/2001 11:19 Re: Fujitsu 30GB & IBM 10GB.. Will it work? [Re: djc]
Could be the battery in the remote. Always check that first.
Edit: You still have the two units there? Does one unit respond to the remote, but the other does not? Do you have the remote for the other unit? If possible, narrow it down that way.
Edited by tfabris (26/11/2001 11:20)
#47737 - 26/11/2001 11:41 Re: Fujitsu 30GB & IBM 10GB.. Will it work? [Re: tfabris]
djc
Loc: chicago
well, in the time it took me to go get the other remote, the first one started working again (they both work now). from a quick search here on the board, that doesn't seem to uncommon, so i won't worry about it for now.
thanks!
--dan.
