#48071 - 30/11/2001 06:34
Re: JEmplode 2.0 Released
[Re: Nosferatu]
Loc: Richmond, VA
Did you happen to notice if your player was frozen? Could you do anything through the normal player UI?
Mike
#48072 - 30/11/2001 12:46
[Re: Nosferatu]
Nothing to do , I had to Off the player then I could use shell.
This is known.
It's actually mentioned in the corresponding FAQ section.
#48073 - 02/12/2001 18:05
[Re: mschrag]
Loc: San Carlos, CA
Hey Mike, can you put up a plain .jar file please? I don't want to use the InstallAnywhere stuff. I have had too many bad experiences with it.
Thanks,
-Mike
#48074 - 03/12/2001 12:24
[Re: tms13]
Loc: Lochcarron and Edinburgh
Here's the serial output when it fails at restart:
player(118): memory violation at pc=0x02078f34, lr=0x020f6fc8 (bad address=0x0000001c, code 2)
pc : [<02078f34>] lr : [<020f6fc8>]
sp : be5fbb08 ip : be5fba80 fp : be5ffcb8
r10: 00000001 r9 : 00000005 r8 : 02244af0
r7 : ffffbea0 r6 : ffffbea4 r5 : be5fbb10 r4 : be5fbb34
r3 : 00000000 r2 : 00000000 r1 : 00000000 r0 : 00000000
Flags: nZCv IRQs on FIQs on Mode USER_32 Segment user
Control: C0EC917D Table: C0EC917D DAC: 00000015
Function entered at [<02078dbc>] from [<020785b8>]
r10 = 00000001 r9 = 0219ADAC r8 = 0219AC50 r7 = BE5FFCC0
r6 = 0219ACF0 r5 = 0219ADAC r4 = 02244AF0
Function entered at [<02078424>] from [<02076a94>]
r7 = 022423F8 r6 = 0219ACF0 r5 = 022423E8 r4 = 0000000C
Function entered at [<02076830>] from [<020ec52c>]
r10 = 020EC474 r9 = 0219AC50 r8 = 0000280B r7 = 00000080
r6 = 0000000B r5 = 0219AC50 r4 = BE5FFD64
Function entered at [<020ec474>] from [<020f3808>]
r5 = 0219AC68 r4 = BE5FFE40
Function entered at [<020f3740>] from [<0212e80c>]
r4 = 00000000
Function entered at [<0212cf80>] from [<020f3584>]
r8 = 0219712C r7 = 02197118 r6 = 020EC474 r5 = 00000003
r4 = 00000000
Function entered at [<020f34d4>] from [<0212e80c>]
r5 = 00000000 r4 = 00000000
Function entered at [] from [<00000000>]
Function entered at [] from []
Function entered at [<23a0fef4>] from [<23a0ff00>]
Unable to handle kernel paging request at virtual address 23a0fef8
memmap = C0EC8000, pgd = c0ec8000
*pgd = 00000000, *pmd = 00000000
Internal error: Oops: 2
CPU: 0
pc : [] lr : []
sp : c0293f44 ip : c0293f00 fp : c0293f90
r10: 00000002 r9 : c0fa80e0 r8 : 0000000c
r7 : 00000000 r6 : 23a0fef4 r5 : 23a0ff00 r4 : e3a02000
r3 : 60000013 r2 : c00fe1e4 r1 : 00000001 r0 : e3a01ff0
Flags: nZCv IRQs on FIQs on Mode SVC_32 Segment user
Process player (pid: 118, stackpage=c0293000)
Stack:
c0293f20: c0019670 c00dfb60 60000013
c0293f40: ffffffff c0fa80f8 c0fa3920 c0292000 c0293fb8 0000001c c0011948 020f6fc8
c0293f60: 0000001c 00000002 c0293fb8 0000000f 0000001c 00000000 00000002 00000005
c0293f80: 00000001 c0293fb4 c0293f94 c0011e80 c00116f8 c00fc978 be5fbb10 ffffbea4
c0293fa0: ffffbea0 02244af0 00000000 c0293fb8 c000a008 c0011da8 00000000 00000000
c0293fc0: 00000000 00000000 be5fbb34 be5fbb10 ffffbea4 ffffbea0 02244af0 00000005
c0293fe0: 00000001 be5ffcb8 be5fba80 be5fbb08 020f6fc8 02078f34 60000010 ffffffff
Backtrace:
r10 = 00000001 r9 = 00000005 r8 = 00000002 r7 = 00000000
r6 = 0000001C r5 = 0000000F r4 = C0293FB8
r8 = 02244AF0 r7 = FFFFBEA0 r6 = FFFFBEA4 r5 = BE5FBB10
r4 = C00FC978
Code: ebfce63f e2440010 (e5961004) e1a035a1 e59f20cc
Restored terminal settings
No secondary hard disk
Abnormal player termination
Player received signal 11
Starting player
empeg-car 2.00-beta3 2001/10/17.
E !! tags.cpp 61: Failed to open tags (0xc0041002).
Rebuild 71194ms
#48075 - 03/12/2001 22:08
[Re: mcomb]
Loc: Richmond, VA
For people who are annoyed by the couple of bugs that have been reported so far, you can grab a replacement jemplode.jar -- This is a little more "unofficial" -- Once we get a couple larger features in, we'll do a "real" 2.0b2 with all the fanfare of installers.
http://www.batmanthehorse.com/jemplode/jemplode20.jar
Just replace jemplode.jar with this in your install directory (or you can actually run this standalone with java -jar jemplode20.jar).
Mike
#48076 - 12/12/2001 16:54
[Re: mschrag]
Loc: NRW, Germany
Hey Mike, is this "unofficial" jemplode release still floating around somewhere? Am trying to use jemplode under Mac OS X 10.1, and it is a little flakey. Thought that the newer jar file might help, but I can't get to it anymore ...
#48077 - 12/12/2001 18:01
[Re: Derek]
Loc: Richmond, VA
It should be at the same place -- I just went to
and it downloaded .... When you say "flakey", can you describe what you're seeing?
ms
#48078 - 13/12/2001 01:57
[Re: mschrag]
Loc: NRW, Germany
Just managed to grab it, thanks! Last night I was getting a 404 error message. Wierd!
The "flakeyness" I've experienced consists of:
Syncs failing with "media check failed" messages. i.e. nothing gets loaded across. The only way to sync successfully way to remove power from the empeg (even though jempeg had performed a soft boot that wasn't enough) and restart jempeg.
The GUI hanging or going REALLY slowly. This would mainly happen after a sync (I took to restarting everything after every sync), but I had it happen a couple of times before a sync. Seemed to be caused by switching to another application and then back - OmniWeb if I remember correctly, but I can check it for you. Had to be real patient waiting for the sync button to come up so that I could save my changes. Sometimes the whole jempeg window would go completely grey, or wouldn't update, and I would have to switch to another program and then back to get the screen updated - the GUI would still be sluggish, but at least I could see where to make the next click :-) Would sometimes block the whole machine!
That's as good as I can remember it this morning anyway. Would be happy to test it further for you. I think doing a drag and drop operation may have triggered the GUI funnyness before a sync. Hmmm. Is still GREAT being able to load stuff across on my Mac. I can stoop to using a Windoze box at work to tidy up tags and playlists (was too annoying in jempeg last night).
Oh, one other thing I noticed, genres are often comming across strange (numbers in brackets instead of tags) and I have been getting -1 for the year quite often too. Maybe I should fix the tags in iTunes first and see how it behaves then ...
Anyway, thanks again for the quick response :-)
#48079 - 13/12/2001 07:04
[Re: Derek]
Loc: Richmond, VA
Thanks for all the details ... Mike Comb reported some of this stuff on OS X as well. I'll break out the OS X laptop and start doing some more testing to see if I can track down what is going on.
Thanks Derek --
Mike
#48080 - 13/12/2001 07:10
[Re: mschrag]
Loc: NRW, Germany
No worries. Actually I tried out the new jar file this morning before I came to work and it seems to be a LOT better. I could sync and jempeg was still quite useable afterwards. Nice :-)
#48081 - 13/12/2001 07:15
[Re: Derek]
Loc: Richmond, VA
Interesting .. I didn't really do that much to change stuff, but that sounds great :) I wonder if it was a weird artifact of the 0x0 pixel windows? Oh well, keep an eye out for those other problems and let me know which ones are still there ... I suspect all the genre and tag related stuff is still there, since that hasn't really changed.
Mike
#48082 - 13/12/2001 18:22
[Re: mschrag]
Loc: San Carlos, CA
Yep, that all sounds pretty familiar. I believe Dan Z promised to come up with a work around for the year bug although it is actually a problem with the tag (there is an ID3 year tag there, but without any content). Are the sources for the ID3 package available somewhere? If so I could probably fix that one myself.
As far as the GUI slowness (ArrayIndexOutOfBounds exception) I just tried again and that does seem to be fixed with the updated version. I had not tested it before since you said you hadn't had time to look at it. Maybe it is related to the updated progress dialogs? BTW, the problem I reported where the dialogs don't always go away under FreeBSD seems to be happening under OS X as well.
-Mike
#48083 - 13/12/2001 18:29
[Re: mcomb]
Loc: San Carlos, CA
Uhhh, nevermind. It just happened again. It was fine for half a dozen test syncs, but as soon as I deleted all the test files I had synced and tried to sync one more time I got this problem again.
-Mike
#48084 - 14/02/2002 05:09
[Re: tms13]
It still has the problem that a lot of the dialogs are iconified and at the bottom of the window stack on their 2nd and subsequent use. This applies to the "Working...", "Tune details", "Playlist details" dialogs, but not to the yes/no/etc confirmation dialogs.
Seems to be fixed in JEmplode 2.0b11.
