#48273 - 28/11/2001 13:57 tune count in 2.0b3??
dewdman42
This has probably been covered before, but I couldn't find anything when I did a search.. Just wondering.. Before the upgrade, when I selected the top playlist to play all tunes in the player (randomly) it showed a count that was almost 3 times as many tunes as after upgrading. When I stopped to think about it...the number now is probably a lot more accurate. Anyone have any knowledge about this discripency? I'm guessing that 1.03 counted playlists as well as tunes or something.. ??
-steve
#48274 - 28/11/2001 14:49 Re: tune count in 2.0b3?? [Re: dewdman42]
bonzi
The only thing that comes to mind is not SW release related (at least not 1.03 vs. 2.0b3 - the bahaviour was different in some early pre-release betas): if you play a playlist unshuffled, the tune counter will simply count all tune appearances in child playlists; if the list is shuffled, it will count only unique tunes.
Update: I just noticed that you say you played randomly in both cases... Hmm, I don't know what that could be. Just a thought: do you by 'random' mean root playlist marked as 'always randomize' or shuffle mode switched on?
Edited by bonzi (28/11/2001 14:52)
#48275 - 28/11/2001 15:04 Re: tune count in 2.0b3?? [Re: dewdman42]
I know you said that it was random, but I second Bonzi's comment. Check out this faq entry and see if this is all you're seeing.
#48276 - 28/11/2001 15:10 Re: tune count in 2.0b3?? [Re: tfabris]
dewdman42
No...that isn't what I was seeing. I just tested it to be sure...but no... I never used shuffle mode before in 1.03. I configured the top level playlist to play randomized so that whenever i played the top playlist...it was randomized... I never even messed with the shuffle on/off feature at all...
I am finding in 2.0b3 that I *HAVE* to use the shuffle feature to see the top level playlist actually play in random order, regardless of what I set for its properties. This seems a little different than 1.03.
In any case, before, under 1.03 I was seeing nearly 14,000 tunes listed (which is obviously not right since I seem to average 2MB/min in my VBR encoded mp3 files.. Now I see around 5500 tunes for the global list.. Turning shuffle on or off has no effect on that number..
Its not that big of a deal. The 2.0b3 number is actually more correct. I was just curious as to why it showed so much before.
