#50015 - 14/12/2001 18:24 pause on AC
thinfourth2
could we have a wee option in the int script so that the player automatically pauses or goes onto standby on AC power as mine goes into its dock when at home and then lives on the network then when it returns to the car it can be a few hours further throught the playlist if i forget to pause it at home.
I don't want a permant pause or standby as i often is called into duty driving the stereo
#50016 - 15/12/2001 00:22 Re: pause on AC [Re: thinfourth2]
It's my belief that this could be accomplished with hijack. I went through a bit of an explanation on how this would be done over in the Programming forum earlier this evening... Basically, the player gets its status (including standby mode and whether it's paused or playing) from the flash. The kernel can give the player phony state data at any time and the player won't be the wiser. So on bootup, Hijack could in theory supply certain values from config.ini instead of the ones from the real flash block. In your case, you would want to define either pause or standby in your config.ini and then hijack would pass that along when booting up. The only caveat would be you want it to only happen on AC power, but since Hijack knows what power source it's on, that shouldn't be a big deal.
#50017 - 17/12/2001 05:16 Re: pause on AC [Re: tonyc]
Dava
Loc: Bucks UK
I agree that this would be an option that I would want but I would go one step further. The player has a different personality at home and in the car, I never turn mine off in the car but always when I have finished at home.
It is anoying when:
I plug it in at home after being in the car and it starts playing.
Put it in the car and it is off.
IMO, the unit should remember its last state on a particular power source and revert to it.
The empeg is fantasic in that it works differently at home rather than in the car and I think most people use a home and car player very diferently to one another. Therefore this should be one of the differences covered by the personalities.
MK2 smoked 32Gb S/n 090000949 MK2a Blue 20GB racked and out of sync
#50018 - 17/12/2001 05:41 Re: pause on AC [Re: Dava]
thinfourth2
Hopefully this would be where we will end up as the radio modules can identify different cars and now that it looks like the backup is ending up in the girlfriends car i would like to see the personnalities enabled
#50019 - 17/12/2001 11:07 Re: pause on AC [Re: Dava]
Most of what you're suggesting can definitely be done with Hijack pretty easily. Play/pause status is by default global (same for home and car) but with some creative tweaking I think at least the startup play/pause behavior for each source could be specified. As for actually remembering your state for that source, that can be done, but would take a little extra work (and borrowing another bit from the flash.) Then as the player writes its pause status, the kernel would decide which bit to write that value to (maybe the current pause bit becomes the "home" pause bit, and an unused bit elsewhere becomes the "car" pause bit.) It could definitely be done. Drop it as a suggestion to Mark once some of the startup behavior hacking makes its way into the Hijack kernel.
#50020 - 17/12/2001 11:13 Re: pause on AC [Re: tonyc]
Based on various bugs/fixes in the 2.0 software that I've seen, I'm thinking that mucking about with the play/pause behavior might be tricky.
#50021 - 17/12/2001 11:18 Re: pause on AC [Re: tfabris]
Can you explain a little more what you mean?
#50022 - 17/12/2001 11:24 Re: pause on AC [Re: tonyc]
I mean that, it was tough even for the Empeg guys to get the player and radio to properly pause/unpause at boot-up time, even when they wrote the player software.
Remember that when the player goes into Standby mode, it's simply paused with the display shut off. It's doing something fancy under the hood to get itself back into the proper state at power-up, and it might be tough for you guys to know what's going on "from the outside", as it were.
#50023 - 17/12/2001 11:27 Re: pause on AC [Re: tfabris]
Hmm... Well, that's all true. However, the approximate methodology I would see would be to make the player software think it's supposed to start up in (play, pause, standby) mode by changing what it gets when it does a state_read(). Then the player itself can do what it normally does (blanking the display, pausing or playing the songs, etc.) There is definitely a bit in the flash for standby, and for pause... So we as the kernel would stay out of the blanking, pausing, whatever business and just make the player think that the power-save behavior was something different than it actually was..
Does that change your opinion a bit? It seems you're worried about us having to do complex manual operations, when in reality, we're just tricking the player, at least in theory....
#50024 - 17/12/2001 11:31 Re: pause on AC [Re: tonyc]
Actually, I'm more concerned about what happens at shutdown time.
#50025 - 17/12/2001 11:44 Re: pause on AC [Re: tfabris]
Ohh... um... Not sure what the concern is... The first step I see is allowing startup behaviors to be defined in config.ini, which doesn't involve changing any of the shutdown/power fail stuff, as far as I can tell. Even with the play/pause behavior described above, it seems all that's needed is to see if we're in AC or DC mode (already available to the kernel) and change the way we save the state accordingly, possibly saving one bit in a different location than is currently done. State isn't just written at power fail time, it's also written once per second, so I don't see how shutdowns would hurt us.
I guess you're privy to more of the details and troubles the Empeg team went through, so any specific guidance you could give would be helpful.
