#50853 - 21/12/2001 22:23 Marked
jwickis
Loc: India
My wish is that the marked files popup when opening Emplode, otherwise I forget them. Failing this then in Emplode the marked column should be ascending w/marked files at top not bottom.
#50854 - 21/12/2001 22:50 Re: Marked [Re: jwickis]
I merely wish for a Soup view of Marked tracks. Maybe what they could do is this:
- Implement a Soup view for Marked tracks.
- If the view is not empty, focus it at startup.
#50855 - 22/12/2001 07:19 Re: Marked [Re: tfabris]
smu
Loc: Germany (Ruhrgebiet)
Hi Tony.
Sounds good. I second that suggestion.
cu,
sven
#50856 - 22/12/2001 07:57 Re: Marked [Re: smu]
BAKup
Loc: Houston, TX
I have to third it. I mark tracks so I can either delete them, or replace them, and it's hard to find all of them easily.
--Ben
78GB MkIIa, Dead tuner.
#50857 - 23/12/2001 03:41 Re: Marked [Re: BAKup]
Go to the search pane and type "marked" into the list. It's easy to find all of them easily.
I'll think about the other suggestions.
The soup thing's a little more complicated than you think, but it's a good idea, 'cos it would make any file taxi functionality easier to use.
#50858 - 07/01/2002 05:34 Re: Marked [Re: Roger]
Finding all marked tracks is dead easy - I always keep the marked column visible. The two things I would like to see are altering of the marked flag from within emplode (looks like it is an available option, but does not propagate to empeg) and different types of mark, so the mark button cycles through mark for deletion, mark for replacement, mark for other attention, perhaps.
#50859 - 07/01/2002 08:35 Re: Speaking of Marked Tracks... [Re: jwickis]
Dearing
Loc: Florida
Could we have marked tracks show up with the !! symbol in Now&Next? Maybe next to the Play Symbol?
Thanks,
Jason
_~= Dearing =~_
