#51798 - 26/12/2001 11:33 lockup after pushing 'down' 3 times
pupvogel
Loc: Hamburg, Germany
My empeg (mk 2 - 2.00 beta 7) locks up after pushing the 'down'-button three times...
The only thing that is displayed is the sandclock, and the buttons don't do anything - so I have to restart the unit.
I didn't see that in beta 3.
#51799 - 26/12/2001 12:14 Re: lockup after pushing 'down' 3 times [Re: pupvogel]
I Shuffle On or Off when you press the down button three times?
If it is On, what is the custom mode selected for the shuffle? And does turning shuffle off fix the problem?
#51800 - 26/12/2001 12:42 Re: lockup after pushing 'down' 3 times [Re: tfabris]
pupvogel
shuffle is off, but the root-directory itself is set to play in random order.
#51801 - 26/12/2001 13:08 Re: lockup after pushing 'down' 3 times [Re: pupvogel]
Interesting. Have you tried turning Shuffle on and then pressing down-down-down? Or turning off the "always randomize" check box on that root folder and re-synching?
If it still has trouble, perhaps there is an item somewhere deep in the tree that's causing problems. Would be interesting to find out which one. Get a serial log if you can.
#51802 - 27/12/2001 06:34 Re: lockup after pushing 'down' 3 times [Re: tfabris]
pupvogel
After I've started emplode beta 7 for the first time, it reported several tag errors.
Also, the root directory was not set to random any more... so I set it to random and did a re-sync - now everything works fine !
#51803 - 27/12/2001 11:09 Re: lockup after pushing 'down' 3 times [Re: pupvogel]
Hmm. Maybe Rob should put a note in the release documentation: "Synch with the new emplode after installing the software".
#51804 - 27/12/2001 11:32 Re: lockup after pushing 'down' 3 times [Re: tfabris]
It might even make sense if the upgrade process offered to kick off a sync for you once the upgrade was complete ?
#51805 - 07/01/2002 06:20 Re: lockup after pushing 'down' 3 times [Re: tfabris]
pupvogel
oops, it did it again... (it's not that innocent )
i tried to catch this in a serial log, but the problem just didn't occur... but there are other things i see in the log that may be connected:
while the unit is playing, i see lines like these all the time:
spindown_chunk_cache_runner.cpp: 292:Filling up space (28)
spindown_chunk_cache_runner.cpp: 292:Filling up space (27)
spindown_chunk_cache_runner.cpp: 292:Filling up space (25)
and on startup i see these lines:
Mounting proc
Starting player
player.cpp : 550:empeg-car 2.00-beta7 (internal) 2001/12/22.
dhcp_thread.cpp : 413:name = lo
dhcp_thread.cpp : 414:index = 1
dhcp_thread.cpp : 415:flags = 0x8
dhcp_thread.cpp : 416:addr = 0.0.0.0
dhcp_thread.cpp : 417:bcast = 0.0.0.0
dhcp_thread.cpp : 418:mask = 0.0.0.0
dhcp_thread.cpp : 413:name = eth0
dhcp_thread.cpp : 414:index = 2
dhcp_thread.cpp : 415:flags = 0x1002
dhcp_thread.cpp : 478:Adding interface eth0
Prolux 4 empeg car - 2.1335 Dec 22 2001
Vcb: 0x405d7000
! mp3_decoder.cpp :1052:Failed to seek to offset 718002, error=0xc0044000
! mp3_decoder.cpp :1047:Failed to find valid sync after seeking to offset 7180
is the problem in there ? and what is the 'reiserfs' ??
#51806 - 09/01/2002 19:19 Re: lockup after pushing 'down' 3 times [Re: pupvogel]
pim
You're describing the exact same problem I have. Even the messages on the serial console are the same. Click here to see my posting.
I was busy preparing a report containing results of tests suggested by others, when one of my harddrives crashed between numerous powercycles.
I'll try to post my preliminary findings soon.
