#52881 - 31/12/2001 12:08 Known Bug: Moving tracks between playlists
I'm surprised that nobody's noticed this: If you move tracks between playlists, they vanish. Possibly completely.
If you can confirm that this happens in beta7, let me know -- it certainly does in the current internal build.
In the interim, don't do that.
#52882 - 31/12/2001 13:04 Re: Known Bug: Moving tracks between playlists [Re: Roger]
eternalsun
Loc: San Jose, CA
The possibly completely comment has me wondering, where do they go?
Calvin
#52883 - 31/12/2001 13:05 Re: Known Bug: Moving tracks between playlists [Re: Roger]
Wow, I haven't moved a track in ages. I've only ever copied tracks.
Now I'm afraid to try it.
#52884 - 31/12/2001 16:04 Re: Known Bug: Moving tracks between playlists [Re: tfabris]
I'll try it in a couple of minutes. I've got a test folder already set up with duplicate tracks conainting bogus tag info - I need to make new ones anyway.
#52885 - 31/12/2001 16:09 Re: Known Bug: Moving tracks between playlists [Re: Roger]
Yup, gone completely. Deletes track from database and deletes track from player. Poof, gone, no more.
This bring up another bug. You don't get a context menu popping up if you right-drag from the right pane to the left pane. It automatically attempts a move.
Maybe someone should issue a general warning? Ah, nevermind, I'll do it. :)
#52886 - 01/01/2002 06:52 Re: Known Bug: Moving tracks between playlists [Re: Roger]
This is probably a very good reason for NEW owners to stick with 1.03 when loading up their players. Moving tracks is a common operation when first organising a player.
#52887 - 01/01/2002 23:33 Re: Known Bug: Moving tracks between playlists [Re: Roger]
I confirm that. That is the bug I noticed and mentioned in another thread here few days ago, but I guess I was not very clear/did not identify precisely the problem.
#52888 - 02/01/2002 08:42 Re: Known Bug: Moving tracks between playlists [Re: Roger]
philb
Yes, this happened to me. It lost all but a couple of playlists that I dragged and dropped, about a gig's worth. When cutting and pasting (rather than drag 'n' drop), the tracks do seem appear in the destination playlist, then disappear at some point later. As far as I can tell the files are completely gone.
Philb.
#52889 - 02/01/2002 09:47 Re: Known Bug: Moving tracks between playlists [Re: philb]
BAKup
Loc: Houston, TX
Look at this post for the workaround on the deleting instead of moving bug.
--Ben
--Ben
78GB MkIIa, Dead tuner.
