#52993 - 31/12/2001 16:15 WARNING: 2.0b7 *Don't* move tracks between plylsts
Ok, if you read the bugs forum, you'll see a post by Roger asking for verification of a "known bug" in emplode 2.0b7.
When moving a track from one playlist to another, the track will vanish: It will be removed from the old playlist but will not show up in the new playlist. Further, the track will also not simply be unlinked from the database. It will be internally tagged for deletion. Performing a sync on your player will remove the track completely (yeah, DELETE IT).
So, if you need to shuffle things around to a different playlist, looks like you're best off using an explicit COPY and then remove the original for now.
Note, if you drag from the RIGHT pane to the LEFT pane, it always defaults to MOVE. To COPY, use the "COPY" edit command or drag from RIGHT pane to RIGHT pane using two windows (Window menu, NEW window command)
edit: damned transposed charcaters. :)
Edited by hybrid8 (31/12/2001 17:03)
#52994 - 31/12/2001 16:58 Re: WARNING: 2.0b7 *Don't* move tracks between plylsts [Re: hybrid8]
muzza
Thanks for the warning. I'd been away for a few days having only just upgraded to v2b7 before I left. I'v just spent nearly 2 hours going thru all the posts. Take a break and the board gets so far ahead! AND this is the holiday season!
#52995 - 31/12/2001 20:27 Re: WARNING: 2.0b7 *Don't* move tracks between plylsts [Re: hybrid8]
You can press the Ctrl key to force a copy, IIRC.
#52996 - 01/01/2002 00:03 Re: WARNING: 2.0b7 *Don't* move tracks between plylsts [Re: hybrid8]
grgcombs
Loc: Dallas, TX
Maybe I did something right, but I don't think this happened to me. I know I didn't do a move, but a copy. And it's still there. It's possible I looked at the properties to unmark it and apply my change. This may have undone a delete?
Greg
#52997 - 01/01/2002 04:12 Re: WARNING: 2.0b7 *Don't* move tracks between plylsts [Re: grgcombs]
No, it only happens with moving, and probably only with drag-and-drop. Anyone care to check if it's broken if you do Cut-and-Paste?
#52998 - 01/01/2002 04:24 Re: WARNING: 2.0b7 *Don't* move tracks between plylsts [Re: Roger]
bonzi
Any chance of fixing it quickly in 2.0b7a or something? I have not finished cleaning up my collection (a task made much easier with emplode_v2), so this is a showstopper for me.
#52999 - 01/01/2002 08:33 Re: WARNING: 2.0b7 *Don't* move tracks between plylsts [Re: Roger]
BAKup
Loc: Houston, TX
Cut and paste also makes them go into never never land...I was watching it sync, and I spotted it for a brief moment saying "Deleteing...(song name)" so I guess it's gone forever.
--Ben
78GB MkIIa, Dead tuner.
#53000 - 01/01/2002 11:05 Re: WARNING: 2.0b7 *Don't* move tracks between plylsts [Re: bonzi]
I'll harangue Mike tomorrow. He's in charge of releases.
#53001 - 01/01/2002 21:46 Re: WARNING: 2.0b7 *Don't* move tracks between ply [Re: BAKup]
BAKup
Loc: Houston, TX
I got it to move properly...What is happening is when you go to delete a playlist entry, and you hit that little checkbox to delete the file along with the playlist entry, it's remembering that...And when it goes in to delete the old playlist entry, it checks to see if you told it to delete the file along with the playlist entry...Quick workaround, go in and delete a junk song/playlist. when it comes up with the box that asks if you want to delete the files along with the entries, uncheck it. Then moves with work fine(at least they are over here).
--Ben
--Ben
#53002 - 01/01/2002 23:40 Re: WARNING: 2.0b7 *Don't* move tracks between ply [Re: BAKup]
WOW!
Great catch! You NAILED that one!
I am -so- impressed.
#53003 - 02/01/2002 03:05 Re: WARNING: 2.0b7 *Don't* move tracks between ply [Re: tfabris]
Yeah, I knew that was what caused it about 2 weeks ago.
It's still a good spot, though, 'cos it ain't that obvious unless you're looking at the code in a debugger.
I'd fixed it already for the HSX-109, but the fix didn't get merged into the car player version of emplode.
#53004 - 05/01/2002 03:19 Re: WARNING: 2.0b7 *Don't* move tracks between ply [Re: BAKup]
A quick way to zap the songs deleted in any playlist is to use the "refs=0" advanced search, and delete the songs that show up there.
Thats what I have been doing, since the workaround of not having the "delete files with playlist" seems to be working.
#53005 - 05/01/2002 10:13 Re: WARNING: 2.0b7 *Don't* move tracks between ply [Re: drakino]
fusto
Loc: Lummi Island, WA
Lets just say for the sake of argument, that I read this thread, noted it, and then went ahead and dragged and dropped between playlists anyway.
Now besides everyone agreeing that that would be a really stupid thing to do, is there any way to do an advanced search in Emplode for files marked for deletion?
And after finding these files, can they be unmarked? Or do I have to re-upload? (Lets also say for the sake of argument all my files are all at work.)
Just curious...
8-)
Zachary
Lost in Boston
#53006 - 05/01/2002 11:58 Re: WARNING: 2.0b7 *Don't* move tracks between ply [Re: fusto]
jwtadmin
Loc: Ipswich, MA
and lets just say that a co-worker looking over his shoulder reminded him of this bug yesterday.......
___ John Turner "It's easier to ask for forgiveness than to ask for permission"
#53007 - 05/01/2002 17:43 Re: WARNING: 2.0b7 *Don't* move tracks between ply [Re: jwtadmin]
fusto
Boy thats helpful!
Thanks...
:-P
Z~
#53008 - 05/01/2002 22:01 Re: WARNING: 2.0b7 *Don't* move tracks between ply [Re: fusto]
Maybe you could Revert Changes (from the File menu) instead of Synchronizing. Of course, that would throw away all your other changes, but that might be better than deleting files.
#53009 - 06/01/2002 03:24 Re: WARNING: 2.0b7 *Don't* move tracks between ply [Re: fusto]
No, you can't search for deleted files (although I might change that), and if you do manage to find any, there's (currently) no way to undelete them (although I might change that).
Don't hold your breath, though.
#53010 - 06/01/2002 07:09 Re: WARNING: 2.0b7 *Don't* move tracks between ply [Re: Roger]
fusto
Yeah, I kinda figured that.
I went ahead with a synch as I had made too many other changes to make it worthwhile to revert back.
I'll just have to remind myself to re-upload those files when I get to work.
Thanks,
Zachary
#53011 - 06/01/2002 07:17 Re: WARNING: 2.0b7 *Don't* move tracks between ply [Re: fusto]
fusto
Actually, Duh...
I've got the CD here at home.
Why dont I just re-rip it and upload it.
What a dope...
Z~
#53012 - 10/01/2002 15:41 Re: WARNING: 2.0b7 *Don't* move tracks between ply [Re: fusto]
SE_Sport_Driver
I just got burned by this... copy and paste... pooof 2 GB gone
#53013 - 13/01/2002 00:14 Re: WARNING: 2.0b7 *Don't* move tracks between plylsts [Re: hybrid8]
redbutt2
Loc: San Diego, CA
I have been able to bypass the bug if I do the moving only in the left frame. It's a little annoying, but stuff isn't getting deleted.
We need a bigger boat.
#53014 - 13/01/2002 20:10 Re: WARNING: 2.0b7 *Don't* move tracks between plylsts [Re: redbutt2]
The reason stuff isn't getting deleted is because you didn't check the little box. I don't think it has anything to do with which frame is being moved.
#53015 - 13/01/2002 20:51 Re: WARNING: 2.0b7 *Don't* move tracks between plylsts [Re: tfabris]
keil
Loc: Los Angeles,CA
Is this bug in b7 kernal or Emplode? If in Emplode, than JEmplode could be used for cut/move. Correct?
Keil
#53016 - 13/01/2002 20:51 Re: WARNING: 2.0b7 *Don't* move tracks between ply [Re: SE_Sport_Driver]
SE_Sport_Driver
RIP the letter C.
(Tony, thanks for the post in the Announcement Forum. Hopefully, it will save more dinks like me! )
#53017 - 13/01/2002 21:20 Re: WARNING: 2.0b7 *Don't* move tracks between plylsts [Re: keil]
Right, the bug is beta 7 emplode only. So in theory Jemplode can be used, assuming it does not have the same bug . However, Jemplode does not do USB at this time, it's ethernet. So those using USB are SOL.
#53018 - 14/01/2002 02:59 Re: WARNING: 2.0b7 *Don't* move tracks between plylsts [Re: tfabris]
bonzi
emplode 2.0b3 can be used with player 2.0b7 and does not have 'delete while moving' bug, right?
#53019 - 20/01/2002 16:37 Re: WARNING: 2.0b7 *Don't* move tracks between plylsts [Re: hybrid8]
Chao
Hee. I was wondering where my songs were vanishing to
