#5369 - 16/12/1999 15:27 Radio
scoco
Loc: St. Louis, MO
Is it just me or is the radio reception really bad? When I'm in town and tune to some stations I can hear two and even sometimes three other stations bleeding over. The further I get from the stations the better it seems to get. Once I'm out of town I can usualy get pretty good reception. Also it seems that when the car is in motion the reception is a lot worse than when I'm stopped.
#5370 - 16/12/1999 21:39 Re: Radio [Re: scoco]
dionysus
Loc: San Francisco, CA
...sounds like your car's antenna is a strong antenna - I had the same problem.. Remove the antenna booster and it should definately get better.
-mark
#5371 - 17/12/1999 08:25 Re: Radio [Re: dionysus]
scoco
Loc: St. Louis, MO
I'm pretty sure you're right, I noticed that I'm now getting a station about 200 miles away that I have never been able to get before. I'll remove it tonight and let you know how it works.
#5372 - 17/12/1999 13:31 Re: Radio [Re: dionysus]
Happy Birthday schofiel
I've just tried this out, and reduced the length of my aerial by about 50% in length. BINGO!!! Instant, very definite improvement.
Of all the things I have tried to improve the radio reception, this is something that had just absolutely not occurred to me - reducing the received RF level. Congratulations, sir, on finding the answer !!! I am now pulling in FM stations from Germany, and from Belgium, for goodness' sakes!! [200km+??]
Hugo has also sneaked in a number of definite improvements to the tuner software - well done, it looks great, and works well. I have improved RDS text handling too; great stuff. I noticed that the number of decimal places in the station frequency has gone up to 2 - is this a sign that you are going to start tuning by 0.01 or 0.05 MHz increments?
What's the mysterious silent station at 96 MHz that comes in at 5 bars? Anything to do with Acorns?
Is there a set of release notes for the 8C version of the radio similar to John's notes for the equaliser, Hugo?
The unit still has the problem that it is unable to discriminate well between adjacent stations, and absolutely not between local and distant stations on similar frequencies. Given that the tuner module has got a control function for Local/Remote selection, how about a button assignment on the remote (and a small on-screen icon to indicate the mode) to select Local/Remote as desired? This would make for vastly improved round-town usage. What about it, Hugo ?
#5373 - 11/01/2000 15:35 Re: Radio [Re: scoco]
Henno
Loc: Meije, Netherlands
I have finally opened up the empeg installation (tonight) and removed the empeg supplied antenna amplifier. You're right! Without the booster, reception is much better , but still far from perfect . From the comments elsewhere I'm pretty sure that there is more to be gained by further reducing the RF input as many of the stations that sound distorted, show full strength reception (5 bars) and, despite the apparent signal strength, receive RDS with errors.
I bet there is another RF amplifier somewhere and that the (very) poor reception before was caused by over-amplifying an already amplified signal. I don't have an external antenna: use the BMW pre-wired 'in-the-windshield' antenna hook-up, so I can't reduce the antenna's length and need another way to reduce signal strength
Does anyone have any advice on reducing antenna output? Are there any 'de-boosting' devices, or does anyone know a kludge that I can solder-up that will have the same effect?
Henno
#5374 - 11/01/2000 19:35 Re: Radio [Re: Henno]
dionysus
radioshack here in town sells a de-boosting adapter..not sure how much that'd help though..
-mark
#5375 - 12/01/2000 04:31 Re: Radio [Re: Henno]
Hoi Henno!
You could look for an signal matching adaptor; I found one that is suitable for FM, which is just a small coil transformer that allows you to adjust the amount of signal going through it. This is an off the shelf module from my local electronics shop, but it was big-time expensive. When I opened it, it was just a miniature FM tuner transformer and a couple of connectors, which could have been bought seperately for about a quarter of the price as loose components. If you're not scared of soldering, then all you need is a miniature FM tuner core, a bit of shielded 75 ohm coax and two connectors. If you are interested, I could try and sketch this and post it here.
It was an Altai brand; I didn't use it after I found I could just collapse the aerial to half it's length and get excellent results.
Are you sure that the built in antenna is not adjustable for RF gain? My friend across the back here had a Volvo amplified antenna built in to his car that we discovered could be adjusted with a little twiddle pot on the case.
#5376 - 12/01/2000 17:22 Re: Radio [Re: schofiel]
Henno
Hi Rob,
Great machine ain't it! I alread started to blame the empeg team for focussing overlooking he FM part, when it turns out that reducing the input signal improves reception. I know, you discoverd this before, but I found it hard to believe . Took me 6 weeks or so to remove the booster and, bingo, FM is acceptable
Advice to anyone with poor reception: Try it out; remove the (empeg supplied) booster and/or shorten the antenna
I'll ask the garage if the amplifier output is adjustable; doubt it though, so if you could sketch up a design, I'll clean it up and post it for general use.
