#5386 - 09/01/2000 14:15 Sony "switch" for sale
dionysus
Loc: San Francisco, CA
As I mentioned before, I have a sony switching unit which allows you to switch between two audio sources for sale... Make me an offer. You can email me at mrahm(at)mse.ufl.edu
-mark
#5387 - 09/01/2000 14:22 Re: Sony "switch" for sale [Re: dionysus]
dionysus
hmm.. the picture didn't come through, so here it is again:
#5388 - 10/01/2000 22:21 Re: Sony "switch" for sale [Re: dionysus]
MRHJr
Loc: CA
Thanks for the posting, but I have to ask how much retail cost is.
It appears to be two channel only, and I would have to buy two, to make my system work, not to mention subwoofer output.I wonder if Sony makes a four channel? Any idea?
Just trying to get ideas in preparation for March:-)
Mk2 #105 60g
#5389 - 10/01/2000 22:25 Re: Sony "switch" for sale [Re: MRHJr]
dionysus
actually, it's four channel; you just can't tell with the picture....
I'm honestly not sure how much it's worth... I paid $150 installed for it about 3 years ago...
-mark
#5390 - 10/01/2000 22:34 Re: Sony "switch" for sale [Re: dionysus]
I'm confused as to what kind of setup would require a switching unit like this. Since the Empeg has an Aux In, and most head units also have Aux Ins, in what situation would one require this?
#5391 - 10/01/2000 22:36 Re: Sony "switch" for sale [Re: tfabris]
dionysus
...It'd be helpful in situations where the Empeg might not be in the car at all times.. would allow the other head unit to be used in the absense of the empeg.
-mark
#5392 - 21/01/2000 01:44 Re: Sony "switch" for sale [Re: tfabris]
Mark Miller
Loc: Southeastern Pennsylvania
It is a wonderful device! I have a Kenwood Excellon PS907 CD/tuner set as my primary source and use the Empeg as the alternate source (both in the dash.) The Empeg's aux connects to a RCA to male miniplug that terminates in my center console where I can hook up a portable minidisc or even a cassette walkman. All these options are only possible because of the tiny automatic Sony switchbox.
When I slide the Empeg out, the Sony switches to the other head unit. It works on the "amp feed line" outputs. If I turn on the other head unit, the Sony will also switch to it. I turn it off to return to the Empeg.
Also, I have music even without the empeg.
Regards,
Mark
--> Get paid to surf the web! http://www.alladvantage.com/go.asp?refid=CCI498
#5393 - 21/01/2000 01:47 Re: Sony "switch" for sale [Re: dionysus]
Mark Miller
Its also useful for head units that can't handle the empegs 4 volts. Or for head units that have a CD controller port instead of an AUX in.
Regards,
Mark
#5394 - 23/02/2000 13:40 Re: Sony "switch" for sale [Re: dionysus]
Les
I appreciate finding out about this switch, but I couldn't make out the model or product number from the picture. Does anyone know the number for this item so I can have my installer get one?
