#57114 - 11/01/2002 16:04
Re: Hijack v114: major bug fixed
[Re: vince]
Cool.
I too am using my Empeg as a portable (60GB) backup device.
#57115 - 11/01/2002 17:40
Re: Hijack v116: Much improved FTP/HTTP servers
I tried that.. and i got:
*** CuteFTP Pro 2.0 - build Nov 20 2001 ***
STATUS:> Getting listing ""...
STATUS:> Connecting to ftp server 192.168.0.2:21 (ip = 192.168.0.2)...
STATUS:> Socket connected. Waiting for welcome message...
220 Connected.
STATUS:> Connected. Authenticating...
COMMAND:> USER
230 Okay.
COMMAND:> PWD
257 "/"
STATUS:> Home directory: /
COMMAND:> FEAT
500 Bad command.
STATUS:> This site doesn't support the 'features' command.
COMMAND:> REST 100
500 Bad command.
STATUS:> This site cannot resume broken downloads.
COMMAND:> TYPE A
200 Okay.
COMMAND:> PASV
500 Bad command.
ERROR:> Syntax error, command unrecognized.
ERROR:> Failed to establish data socket.
-Greg
#57116 - 11/01/2002 17:47
[Re: mandiola]
The "PASV" means your ftp client is trying to do "passive ftp". Tell it not to do that, and life will be good. Happy Days, chap!
#57117 - 11/01/2002 19:43
Hijack v118: more bug fixes, screen capture
Okay, v118 is out, with all of the minor bug fixes (except ".C") for problems that have been reported (few).
Also new, on an experimental basis, is /proc/empeg_screen.tiff
If you access this file (using kftpd or khttpd, for example), it grabs the current empeg screen buffer and returns it as a .tiff (image/tiff) file -- many browsers understand this format, and all image editors (eg. gimp, photoshop, xv) do as well.
I will likely convert it to .png soon, for better browser compatibility. Then all we need is some html and javascript, and we'll have almost full displayserver equivalency from the kernel and your favorite web browser. I'll add http "POST" for remote button presses later as well.
#57118 - 11/01/2002 19:51
Re: Hijack v118: more bug fixes, screen capture
I don't know if I've said this lately.
Mark, YOU DA MAN.
#57119 - 11/01/2002 21:09
Impressing. Really. If I think of how the empeg will look like in just few months if Mark keeps improving hijack at this amazing pace... wow!
#57120 - 11/01/2002 22:33
Sheesh! It's been almost three months since I last heard that!
#57121 - 12/01/2002 00:27
Loc: Dover, NJ
ML,
You're my hero. Seriously.
- Chris
Orig. Empeg Queue position 2
#57122 - 12/01/2002 02:02
Loc: Southwest
"...It's full of stars....."
This is so amazing. Mark, you are unreal!
#57123 - 12/01/2002 05:13
Loc: NORWAY
#57124 - 12/01/2002 05:21
The png option would be appreciated, IE does not appear to like TIFFs.
Also, some apps don't like the tiff you are generating. Photoshop shows them fine, but ACDSee strectches the images so that it is 128x512 in size.
A png file should get it to fit in a single Ethernet packet too...
#57125 - 12/01/2002 10:43
[Re: andy]
Well, actually, the latter behaviour is what I was trying to achieve, using the "resolution" (scaling) parameters embedded in the .tiff file. The problem with 32x128 "native" resolution is that it's just plain too tiny to see very well on a 100dpi screen.
The scale factors I encoded are supposed to cause it to be displayed "actual size", the same dimensions as the actual Empeg front panel display.
But no bother.. .png is a completely different (and way more fscking complex) format for this.. ugh.
#57126 - 12/01/2002 10:53
How about an RLE encoded BMP instead then ?
#57127 - 12/01/2002 11:19
[Re: andy]
Actually, .BMP was the first attempt.. none of my browsers here supported it (I suppose IE probably does, but nobody else).
#57128 - 12/01/2002 14:03
I haven't found a browser that supports tiff yet either, neither IE or Mozilla do...
#57129 - 12/01/2002 18:01
Hijack v119: MUCH faster directory listings
Okay, Hijack v119 is now out at http://empeg-hijack.sourceforge.net/
New in this version:
-- ftp/http error message always go to the console, even if verbose=0
-- ftp/http directory listings are MUCH faster now
-- some built-in mime types for common file extensions
The faster directory list enhancement makes a big difference when accessing the /fids/ directory on a unit that has a lot of tunes installed -- really speeds up restore/backup functions.
#57130 - 12/01/2002 20:29
Mark (or anybody who can help me), I searched and could not find it, so, sorry to bother, but did you implement a command in the config.ini to change the port of the http server, just like the one for the ftp server?
Thank you!
#57131 - 12/01/2002 20:43
[Re: Taym]
I believe it's in khttpd_port, but bring up the kernel patch file (either in your browser or notepad) and do a search for khttpd.
#57132 - 12/01/2002 20:54
[Re: tonyc]
It didn't work. Maybe it has not been implemented yet...
#57133 - 12/01/2002 21:33
[Re: Taym]
I think the "[hijack] khttpd_port=nn" option for config.ini may have been broken for a release or two, but it should work fine in v118 and v119.
#57134 - 13/01/2002 04:43
Re: Hijack v119: MUCH faster directory listings
Loc: Jylland, Denmark
Hi,
Your improvements are totally awesome, dude! :-)
How about a SITE RW and SITE RO (and the kftpd should automagically do a SITE RO if a user invoked SITE RW after logging off).
I just got my "virgin" RioCar plugged in. It doesn't get anything uploaded until:
- Upgrade to 2.0b7
- Patch logo to empeg Tux
- Install newest ML-Kernel.
Which doubles it's value to me, compared to the stock V1.02 it ships with.
Lars
MkII 40gig 090000598
#57135 - 13/01/2002 06:06
Loc: Copenhagen SW, Denmark
The NFS-software for my Psion implements remote control
by "chdir"'ing into "virtual" directories and "cat'ing" virtual files.
I guess posting to /proc woould work, but not be as "user friendly" from a web-browser /ftp browser
Marius (Escort Cab + Mark II)
#57136 - 13/01/2002 07:07
I couldn't get it to work in 119, but it works perfectly in 120. Thank you!
#57137 - 13/01/2002 08:53
[Re: Taym]
Now that's interesting.. I wonder why v119 didn't work -- no difference in that code at all for v120.. must be a race in there somewhere, probably with the semaphore. I'll fix that by initializing the semaphore earlier.
thanks
#57138 - 13/01/2002 08:57
[Re: jane]
Well, everything under /proc/ is virtual, files or directories. I am not sure what you meant.
#57139 - 13/01/2002 09:12
Yes... of course... In my above mentioned psion remote control, these files are not present on the actual filesystem, only when accessed by NFS, and the NFS-daemon does not treat them as files, but as commands.
I guess the /proc/ files could be used directly in the same manner?
Could you have a file /proc/empeg/play that will do a "play" function when *read*?
#57140 - 13/01/2002 10:28
[Re: jane]
How about when *written* instead?
Something like:
## send "play" button code:
echo "20df18" >/proc/hijack_input
## send "next track" button code:
echo "20df11" >/proc/hijack_input
#57141 - 13/01/2002 10:38
I realise it will be easier to implement on the server-side when
you activate by writing to /proc files.
My reason for wanting action when read is that I can point my FTP-client to /proc/, and then just click each file to achieve
the relevant "action".
Otherwise, I guess would have to have a fine that I upload each time, and check the name and content before uploading etc...
But... don't get me wrong. The support you are suggesting is 99% very very good for me :-)
#57142 - 13/01/2002 16:15
Exactly what I wanted to ask for (well, either a pseudofile in /proc or a device file in /dev...)
Dragi "Bonzi" Raos
Q#5196
MkII #080000376, 18GB green
MkIIa #040103247, 60GB blue
#57143 - 14/01/2002 09:07
[Re: Wire]
For now, v123 has limited SITE EXEC capability: the command output is NOT captured and returned to the user, so you have to ensure that the command is correct before sending it.
For example, this will not work: SITE EXEC ro
But this example here will work: SITE EXEC /bin/ro
The command output goes to the serial port, instead of back to the user. I will probably leave it like that for a while (BIG JOB, lots of code bloat needed to fix).
