#57764 - 10/01/2002 23:16 Windows XP's Firewall & Emplode
Diznario
Loc: Portland OR
I'm running Windows XP, and I want to be able to synch my player via ethernet, and also have the built in firewall enabled. Anyone know how to do this? I asked this question once before, and I got this as a response:
ICS active causes the TCP/UDP port that emplode uses to be blocked. You should enter it manually in the allowed ports table.
Now this sounds fine and dandy to me, but unfortunately, I can't seem to figure out how to do it.
So, does anyone know how to do this under XP?
Dario
MK2 in an Impreza 2.5RS
#57765 - 11/01/2002 05:14 Re: Windows XP's Firewall & Emplode [Re: Diznario]
richyrich
from memory (therefore, it's probably wrong !!), I think you need to open up ports 8300 & 8301 for TCP. Don't run XP though (only Mac os 9 .2 / 10.1, linux rh 7.2, 5.1 and win 2k and 98).
Rich.
#57766 - 14/01/2002 18:40 Re: Windows XP's Firewall & Emplode [Re: richyrich]
Diznario
Loc: Portland OR
Hey, thanks for the info! Everything seems to be working fine now...
In case anyone is interested, here's the rundown:
Open Network Properties, right click on Local Area Connection, and select Properties.
Click on the Advanced tab, hit the Settings button. ("Internet Connection Firewall" should be checked)
On the Services tab, click on the Add button.
Enter a name for the service. (I called mine "Empeg")
Enter the IP address of the player, and enter ports 8300 & 8301.
Click OK, and Emplode should now work fine.
Dario
#57767 - 14/01/2002 19:02 Re: Windows XP's Firewall & Emplode [Re: Diznario]
Thanks, that's now a FAQ entry. With credit.
#57768 - 15/01/2002 01:16 Re: Windows XP's Firewall & Emplode [Re: tfabris]
Diznario
Loc: Portland OR
Fine with me.
Dario
