#57916 - 11/01/2002 11:01 Custom Static Image
chris_vd
Loc: Dallas, Texas
Surely it can't be too difficult to be able to upload a custom "static" image to eht Empeg.
Nothing fancy just something that is resides as a static image while the unit plays.
Sorta like the "Tux" visual, but with my own image.
#57917 - 11/01/2002 11:48 Re: Custom Static Image [Re: chris_vd]
Static images will eventually burn into the VFD (faintly). Might not want to do that.
#57918 - 11/01/2002 11:51 Re: Custom Static Image [Re: chris_vd]
mtempsch
There is software to do that; needs to be run on the empeg commandline though.
If I've understood it correctly, it's a binary player hack - the software scans the player binary for where the Tux Much image resides and then replaces those bytes. I don't think anythings changed so that it can't be used.
It's called setvisual and downloadable from Frank van Gestel
I think the README is out of date, but IIRC, if you run the program w/o arguments you'll get a help text.
Edit: If I'm unclear above: it'll replace the image used in the static visual (Tux)
Edited by mtempsch (11/01/2002 11:52)
#57919 - 11/01/2002 12:56 Re: Custom Static Image [Re: mtempsch]
Dearing
Loc: Florida
That's the same bitmap in TuxTooMuch, too, isn't it?
_~= Dearing =~_
#57920 - 11/01/2002 13:56 Re: Custom Static Image [Re: Dearing]
mtempsch
I don't know, I've only ever just zapped through TuxTooMuch, but it might well be.
Lets start it up and take a look... Uh-oh... Just got the No drives found, contact support message :-( Second attempt got it going, further attempts doesn't...
Time to check if the connectors are properly on, or if it's a dodgy cable...
Be back later,
