#57929 - 11/01/2002 12:47 empeg won't wake up
crewe
Don't panic - it works ok in the car! But when I plug it into the mains it just sleeps. The white light just fades in and out, and no amount of button pushing can awake it. I have tried using it in the car and then just pulling it out (awake) and then plugging it in inside, but no luck. I reeeally want to load some new tunes - help! Sally
#57930 - 11/01/2002 13:00 Re: empeg won't wake up [Re: crewe]
Wow, I've never heard of this one before!
Wait, maybe I did. If you plug the player into the USB port of a PC that is turned off, it might lock up when you apply power to it. I think that's even in the release notes. Maybe you just need to turn the PC on first or unplug the USB cable. Is that the problem?
If not, definitely contact support about this one. And let us know what it turns out to be.
#57931 - 11/01/2002 13:18 Re: empeg won't wake up [Re: tfabris]
crewe
Doh! I guess it would help if I ued the right adapter.... : D
#57932 - 11/01/2002 13:43 Re: empeg won't wake up [Re: crewe]
Ah yes, Electricity. That thing Muddy Waters invented. Always helps to have enough of that.
