#6125 - 24/09/1999 18:30 Emplode Sort Function
Dearing
Loc: Florida
Can there be added a field in the database for track number? Most of my uploads are complete CD's, and they don't always end up in the right order. I've been keeping the Track # in the "comments" ID3 field.
This might also be accomplished by sorting on the FID field in Emplode, but that function doesn't work.
Thanks.
_~= Dearing =~_
_~= Dearing =~_
#6126 - 28/09/1999 16:40 Re: Emplode Sort Function [Re: Dearing]
n6mod
Loc: Berkeley, CA
This is, coincidentally, almost exactly what ID3v1.1 does. It takes the last byte of the comment field and uses it for track number. Seems like ID3v1.1 would be a relatively small enhancement to emplode.
(Of course, we're all hoping for v2.3, but that's a bit more effort.)
BTW, there is a short-term workaround to the track ordering issue. Some have suggested prefixing the file name, which is IMHO ugly. What has worked for me is sorting by date in explorer before drag-and-drop to the emplode window. Since AudioCatalyst rips then encodes each track in sequence, the dates match. Of course, if I go back to edit ID3 tags, I'm hosed.
-Zandr
Mk.IIa #010101243 currently getting a 500GB SSD. More spares in the shed.
#6127 - 29/09/1999 02:54 Re: Emplode Sort Function [Re: Dearing]
Mark Petersen
Loc: Denmark, Kbh Ø
in addition to a sort it´l be nice with an select FX.
play sort by filed (use left/right)
| artist | title | album | nr | XXX | YYY | ZZZ |
select (pooldown menu)
STEP 1 (select filed to reduse list by left/right)(select line up/down)
| *(ALL] |
| AC/DC |
| DipIt |
| Quen |
| XXX |
| magic |
| Radi gaga |
| breakthru |
Mark
emaks rouls #10677
want a 100GB model, even I only have colecet 18GB
Mark wait for mk III with a USB Host/slave (USB->GPS)(USB->Bluetooth)(USB->You name it)
