#6166 - 04/10/1999 17:09 I wish for...Audio Cues
Deanster
Loc: Ventura, California, USA
Okay so I'm driving into work this morning with the top down on my car, the Empeg blasting, and grew tired of
the playlist I I was listening to. With the top down on the convertible I can't read the Empeg screen at all. I can't
pull off the freeway everytime I want to squint at the Empeg and run down through the menus to change playlists.
So I was stabbing at the Empeg blindly, trying to find a new playlist that fit my mood. Bah!!
Initially I was wishing for a way to just jump to a different playlist, I could find one that I wanted that way
but then a better interface occured to me:
The menus could all include audio equivalents. So as I step though the menus the text is said over the
speakers. I imagine that each menu could have a tiny mp3 associated with it. I'm thinking an English woman's
lightly accented voice:
Volume...Fader...Next Visualization...Playlists......Self-Destruct Sequence Initiated....
Of course that let's you step through the standard menus but how to step through what may turn out to be
hundreds of playlists? Have Emplode generate a tiny mp3 attached to each playlist when it is defined. By
default it's a computer voice saying the playlist title or optionally the user overides with a relevant music sample.
Then you could step though your Playlists:
Classic Rock...Alternative...Electronic...Dance...
One open-source text to speech project is available here.
yours, Dean
#6167 - 05/10/1999 10:46 Re: I wish for...Audio Cues [Re: Deanster]
Voice prompts, including a self-recorded audio tag for your own presets (and all the "factory" voice prompts being in a replaceable/updateable playlist, so you can rerecord the prompts yourself) are on the to-do list, you'll be glad to know :)
#6168 - 05/10/1999 11:37 Re: I wish for...Audio Cues [Re: altman]
Deanster
Very sweet!! I can't wait. =)
Off subject but I'm sitting here happily shoving muisc at my Empeg through the new Linux interface.
I'm happy since the few win98 (and win2000) platforms I had access to dried up a few weeks ago and
I still have a LOT of space to fill up.
yours, Dean
#6169 - 05/10/1999 11:41 Re: I wish for...Audio Cues [Re: Deanster]
xml
Festival is a bit big, instead I downloaded rsynth and cross compiled it.
Unfortunately, I can't get it to work on the empeg, though it works on my redhat
box. When I strace it it all appears to be functioning; it does some ioctls on
/dev/dsp and then writes data to it, but no sound. I also compiled aumix
and checked that the volume hadn't been turned down, but no luck. Anyone
got any idea? Does /dev/dsp have to be written in 4608 byte chunks as well as
/dev/audio? I modified rsynth to do that but it didn't make any difference.
Some other useful links to links here
Paul
#6170 - 05/10/1999 12:13 Re: I wish for...Audio Cues [Re: xml]
You have to unmute the audio - Mike has a program to do the correct ioctl, I'll prod him tomorrow :)
#6171 - 06/10/1999 03:56 Re: I wish for...Audio Cues [Re: altman]
mac
Loc: Cambridge, UK
Well, he hasn't prodded me yet but here's some untested code that might prove useful.
Mike Crowe
I may not be speaking on behalf of empeg above :-)
Mike Crowe
#6172 - 06/10/1999 05:34 Re: I wish for...Audio Cues [Re: mac]
xml
Thanks, but no luck. It said it was already unmuted and rsynth's "say" didn't
say anything.
Does the following indicate anything obvious to you?:
./strace -fetrace=stat,open,write,ioctl ./say hello
open("/etc/ld.so.preload", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY) = 3
open("/lib/libm.so.6", O_RDONLY) = 3
open("/lib/libc.so.6", O_RDONLY) = 3
open("/dev/dsp", O_WRONLY|O_NONBLOCK) = 3
ioctl(3, SNDCTL_DSP_SPEED, 0x201924c) = 0
ioctl(1, TCGETS, {0x1002 /* B??? */ opost isig icanon echo ...}) = 0
write(1, "Actual sound rate: 8000\n", 24Actual sound rate: 8000
) = 24
write(3, "\200\200\200\201\201\200\200\200\200\201\200\200\200\201"..., 4608) = 4608
ioctl(3, SNDCTL_DSP_SYNC, 0xbffffdd4) = 0
#6173 - 06/10/1999 11:49 Re: I wish for...Audio Cues [Re: xml]
A couple of things spring to mind:
a) We don't support 8000Hz, only 44.1khz. You can expand the sound data yourself though - and we do intend to offer other rates at some point.
b) The data looks vaguely 8 bit and probably mono. We offer 16 bit stereo only. Again, you could post-process the output buffer yourself.
hugo
#6174 - 06/10/1999 15:10 Awesome! Re: I wish for...Audio Cues [Re: altman]
CHiP
That's great Hugo! So that means that i can make my own sounds for each function, and playlist, or use default ones? That's neet because you wont have to look down at the playlists anymore wile driving.
-CHiP
-CHiP
#6175 - 06/10/1999 23:56 Re: I wish for...Audio Cues [Re: xml]
brianosaurus
Can rsynth and the player co-exist on the sound hardware? Assuming I
build rsynth (and sox to get the sample rate&size right), can I run it
while the player is going? Or can only one program hit the sound devices
at a time?
(I'd try it out myself, but I left my freakin' serial cable at work)
brian
#6176 - 07/10/1999 01:28 Re: I wish for...Audio Cues [Re: brianosaurus]
xml
> at a time?
Right, I've tried it. It seems only one device at a time. I think I'll put
esd on it. Any chance empeg can put esd (enlightenment sound daemon) support
into the player? :-)
Here's what I did to get rsynth to work:
Cross compiled rsynth and sox on linux, transferred to empeg.
./say hello there paul -l hello # Puts output in file hello
./sox -s -w -r 8000 -t raw hello -r 44100 -c 2 baz.au # convert to empeg fmt
dd if=baz.au of=/dev/dsp bs=4608 # send to dsp in 4608 byte chunks
Paul
#6177 - 07/10/1999 04:36 Re: I wish for...Audio Cues [Re: altman]
jstrain
Loc: philadelphia pa
you guys at empeg are animals. now i only i wish i could afford one. i'd be listening to it right now if i could have. o well. maybe next time i'm contacted. any idea when mid 1000's defers will have the chance to reorder?
oh, i wish i wish i had an empeg...
12 gig, green...
